Cometdevil
- Dec 19, 2008
Thanks. Looks like need to hold update. Seems like every update has new problem
My Sony Z3c recently have to send in for repair after using only for 6 months. So I got Mi4i to use temporary. For a $270 phone, it is really excellent, the battery last as long as my z3c, the screen is superior and even the cam is quite good.
I quite like using this phone.
i checked the xiaomi forums and there seems to be a bug with the firmware that affect the rear camera. photos are blur when shooting far objects but sharp when shooting near. anyone experience this?
no update latest cant comment
dun update first loh
I experienced this in the update before the latest one. I posted here previously but didn't post a photo yet.i checked the xiaomi forums and there seems to be a bug with the firmware that affect the rear camera. photos are blur when shooting far objects but sharp when shooting near. anyone experience this?
Sent from Xiaomi MI 4I using GAGT
Didnt try. Scared got more problemsoh so the latest update solved this problem for u?
Zzz.. didnt notice my phone auto apply update and restart when i slept at night.
Good thing is i havent noticed any bad bugs
I had this problem regards of the speaker.. The volume becomes softer every sec after I use the speaker (for example call using speaker or play music through speaker) then it stop at a certain level.. Anyone experience same problem? I encounter it both on calls and media even I using speaker..
nope, no such problems, very loud from speaker even for 50% setting.
check your audio output to headphones? or noise supress using 1 mic or 2 mic
Can anyone help mi with it? ? How to check whether audio output to headphones? ?? Noise supress using dual mic. Anyway what the different single mic and dial mic. ...
I just encounter a new problem. .. when i pick up a call, it's on loud speaker mode with the loud speaker not activated on screen.... Pls help. . I feel my mi 4i is going crazy. .. thx in advance. .
