zoossh
- Oct 28, 2000
“Quarterly Cash Rebate for the first Quarter may be awarded on a pro-rated basis as follows:
i) where the Minimum Amount for a Tier is only met in the third Statement for the first Quarter, then one-third of the Quarterly Cash Rebate for that respective Tier will be awarded;
ii) where the Minimum Amount for a Tier is only met in the second and third Statements for the first Quarter, then two-thirds of the Quarterly Cash Rebate for that respective Tier will be awarded; or
For the purpose of this clause, the first Quarter means the period of three consecutive calendar months commencing from the date on which the Principal Cardmember is first issued a Card. “
i read the above and dun see how it conflicts with trazora kor kor's explaination. if there is really a mistake, it is best that u use his example, change the area that is wrong (if it is), and color code in red. we have to admit whether or not there is a mistake, his way of explaining things is good and clear, so if u r pointing it out, you should use his method as well.
Under the new tnc, u shld try to hit max 2k for 3rd mth or 2k for 2 mths if time/spend permit, to get max 1/3 = $100 or 2/3= $200 rebate.
good advice. do u know roughly how long it takes for them to process and approve? i'm thinking of hooting one more card and spend 2k in the 3rd month, and hopefully to get my statement date in earlier part of each month. so planning when to submit application will help to get the desired statement date well.
When in doubt, call hotline to double confirm, never take risk with your own money by relying solely on what others say, especially talk not based on experience or confirmation from authorities, hahaha
moi only semi concur. you yourself is the living example that experience from others are far more important. note that when we call in, we only get the cso, the card and other department who handle the job dun talk to us and only can call out we cant call in. they dun communicate well between departments.
most if not all of us had similar experience of the cso telling us what is not true. do u remember that all of us had received conflicting info on bonus plus account and when is the best time to put in money? u put in money in june to huat, and i did so in sep for premium dividend to huat. if i relied on the cso and not on your experience, i wouldnt have huat.
