Any chance of providing a link for the RT-AC3100 Router updated FW also? Thanks
Hi jbodean96,
RT-AC3100 router not available in Singapore, so i won't be posting the firmware.
Hi Guys,
Anyone has any link or guides to optimize the Smart Connect feature or I just leave it as default will do? TIA and Happy Chinese New Year to all!
Nick.
Hi gohnick,
Just leave it default or you can adjust Dwell to 1600.
Default - 3600/60 = 60 minutes - 1 hour waiting time switching from 2.4Ghz to 5Ghz
Help pls....
Just bought the ac88u. Cannot detect Internet...stuck at detect your connection type after selecting automatic IP. Thanks
Firmware version off the box is
3.0.0.4.380_664
Hey Guys, need some advice here. Planning to put a Access point on the second level of my house. But before I do that, I would like to clarify some stuff. Currently, I'm using the RT-87U and thought of getting a RT-88U for my access point.
1. It is okay to have different models for Access Point?
2. How the RT-88U so far? Should I wait for a more stable firmware before getting it?
Hi evildoctor,
Replace your RT-AC87U to RT-AC88 as main router.
RT-AC87U set as AP "Access Point"
RT-AC88U currently very stable and you can ahead and install the firmware 3.0.0.4_380_2064 - Can be found on the previous form page.
Okay thank you! But why should I replace rt-87u as my main router? Cause most likely, I would like to have stable wifi on the second floor.
Dear Evildoctor,
RT-AC88U NAT raw speed WAN- LAN/Wireless is faster than RT-AC87U.
Anyway RT-AC88U is much stable than RT-AC87U in term of every feature.
Okay. Thank you very much for your advice! Should I consider The AC5300 also? Or get the AC88U?
Just get RT-AC88U.
Hi @poor_poor, ,may I know why you suggested RT-88U instead of RT-AC5300? Because I m also considering buying one of them.
Hi Mksing,
RT-AC88U is faster than RT-AC5300 even both using same chipset.
WAN - LAN/Wireless
For easier reference,
Hi Mksing,
WAN - LAN/Wireless
