[Maylyn - Networking] ASUS RT-AC88U
gohnick
Hi Guys,
Anyone has any link or guides to optimize the Smart Connect feature or I just leave it as default will do? TIA and Happy Chinese New Year to all! :)
Nick.
poor_poor
Hi Guys,
Nick.
Hi gohnick,
Just leave it default or you can adjust Dwell to 1600.
Default - 3600/60 = 60 minutes - 1 hour waiting time switching from 2.4Ghz to 5Ghz
Doraemon70
Help pls....
Just bought the ac88u. Cannot detect Internet...stuck at detect your connection type after selecting automatic IP. Thanks
Firmware version off the box is
3.0.0.4.380_664
ngbc
All 'RT' router affected :
Bad UI Design Sabotages Security of ASUS SoHo Routers
Doraemon70
Problem solved....just a simple click on the iptv and select 'singtel-others' thanks for reading
Help pls....
3.0.0.4.380_664
evildoctor
Hey Guys, need some advice here. Planning to put a Access point on the second level of my house. But before I do that, I would like to clarify some stuff. Currently, I'm using the RT-87U and thought of getting a RT-88U for my access point.
1. It is okay to have different models for Access Point?
2. How the RT-88U so far? Should I wait for a more stable firmware before getting it?
poor_poor
Hi evildoctor,
Replace your RT-AC87U to RT-AC88 as main router.
RT-AC87U set as AP "Access Point"
RT-AC88U currently very stable and you can ahead and install the firmware 3.0.0.4_380_2064 - Can be found on the previous form page.
evildoctor
Okay thank you! But why should I replace rt-87u as my main router? Cause most likely, I would like to have stable wifi on the second floor.
Hi evildoctor,
poor_poor
Dear Evildoctor,
RT-AC88U NAT raw speed WAN- LAN/Wireless is faster than RT-AC87U.
Anyway RT-AC88U is much stable than RT-AC87U in term of every feature.
evildoctor
Okay. Thank you very much for your advice! Should I consider The AC5300 also? Or get the AC88U?
Dear Evildoctor,
poor_poor
Hi @poor_poor, ,may I know why you suggested RT-88U instead of RT-AC5300? Because I m also considering buying one of them.
Hi Mksing,
RT-AC88U is faster than RT-AC5300 even both using same chipset.
WAN - LAN/Wireless
dam02sg1
advice on wifi-signal
hi guys, I had brought the asus 88u and have been using it for awhile. It seems like the wifi signal that I have been getting is worse than my pervious asus router which I had place inside the TV console. Any ideal how to I bridge the 88u to xiaomi router (secondary router).
ASUS@SG
Suspended
Hi colincjw,
Do you enable the AiProtection, Adaptive Qos or Traffic Analyzer option? If yes, please try to turn off them and check the speed again.
Thank.
For easier reference,
