Air purifier? - Part 2
WussRedXLi
BTW, the thicker the HEPA depth (ie folded depth, the pleating...more surface area, you know the drill), the more airflow and less resistance there is.
So customise is good.
Piezoq
Short q. Does the mi air purifier 2 use the same filter as its gen 1 relative?
Hunting for a replacement.
Asakura
taobao.
green. can get rid of Formaldehyde(甲醛)
got offer. 129 only
cheaper den the normal blue one that comes by default
Tofuuuuuuck
Hi all, i recently got a xm purifer 2. I tried using the favourite mode (Coverage 15~18m2) for 3 days. The Clean air delivered is 3167m3 and running time is 24h. So its around 131.95 m3/h. Is this enough? 15~18m2 fan noise is still bearable. More than that can be slightly unbearable. Im going to try "Auto Mode", will it be better in terms of CADR?
Im using it for my asthma and dust allergies. Im in a non MBR (hdb)
Thanks!
Kinetic
Alwaysb
Xiaomi air purifier 1 wifi
Hi,
Ant expert here? Finally bought xiaomi 1. But i can't seems to connect the wifi. Scan, found the device... connect till 80%, always say time out... try again.
Can anyone here help me please? Thank you
NWT1978
Hi,
those portable wifi dont work... those using mobile phones as hotspot also dont dont...
go search for which routers will work...
Alwaysb
ur wifi is wep or wpa?
hidden ssid?
Hi, I managed to connect. Doesn't seems to be the same as the youtube video i saw.. haha.. anyway thanks for your reply.
Are you using xiaomi too? I noticed when i turn on the machine at strong mode... after a while it will turn to auto mode... is it normal?
Within the app, besides the 3 modes, there are speed as well. When do I use the speed function? Any advice?
Alwaysb
taobao.
got offer. 129 only
Hi regarding the filter, after i remove the plastic wrap, i noticed the filter still has another hard plastic in it. Can anyone advice, do i need to remove too?
Asakura
i never use turbo long enough for it to change speed. maybe its to prevent overheat? i usually on for 15mins of turbo and go auto.
Lucky177
XiaoMi2 also same. It will auto toggle from your Favourite mode back to Auto mode. Normal.
Alwaysb
Thanks for the reply. How about auto mode? Hoe does the sensor work? Does it power up if air is not good? I noticed it doesn't.
By changing the speed mode, will it help?
NWT1978
tildveryn
