Air purifier? - Part 2
NWT1978
thanks thanks.
wonder which one is reliable and original?
because i know taobao sell alot of fake products from china... so just wanna be careful...
read reviews.. those blue crowns or gold crowns should be safer but still a risk...
go for rating above 4.8 for all 3 criteria...
then wait for item to arrive and then u know... purchasing items online at Taobao need to risk some as items can be good...authentic or not authentic ones =:p so usually will not get too expensive ones... if received faked ones will not be painful that much and take it as lessons learnt... then blacklist that particular sellers :s22::(=:p
WussRedXLi
any idea where to buy cheap xiaomi filter?
taobao i see.. but cant seem to buy. eg
https://world.taobao.com/item/53259...000&pvid=52d603e6-8ad2-4fc6-88fd-09335e3601b0
If you get that error message, it's coz you have selected Worldwide or Singapore as the country setting. You see the link that you have provided, it's http://[B]world[/B].taobao.com
You can use China as the setting and then re-do the search, bring you to the product page and then you can purchase it.
I have purchased other stuff before due to the above error, no worries. It's legit.
It's not the same error message as those items eg 18650 li-ion batteries, that one cannot be bypassed by such a method. So don't worry, can be shipped.
Can try the filter from this link.......
https://detail.tmall.com/item.htm?s...cm_id=140105335569ed55e27b&pm_id=&abbucket=11
Can try Simplypost. Don't worry about it being labelled as special goods, coz special goods goes by the same $$ rate as normal goods, absolutely no difference at all. (You can weigh the package once it reaches you, no diff).
4PX also dropped its rates......so if you are still afraid, use 4PX.
tildveryn
thanks for your tips
nuky8181
Hi all,
I need advise on getting a warm air humidifier for office. I read in the old thread that Humidifier NH900 is quite noisy.
Anyone has a better recommendation?
Regards
DarthGW
any links to good air purifier. dont mind buying from qoo10
probably need more than 2 units:o
DarthGW
searched in qoo10, samsung ax40 got so many models:
AX40K3020GWD / AX40H5000GMD / AX40H5000UWD :s22:
Gixxerfied
q10 many seller oos liao..
I hooted xm ap2 from funky chargers over at q10 just now..Lazada have thou..
kandinsky
If specs similar, I would just get the one I can find the best deal for.
qoo10 now got sale event with $30 off $200 coupon btw.
http://list.qoo10.sg/gmkt.inc/Special/Special.aspx?sid=14431
Buckbrick
Q0010 got some local stores selling XM2 at $198. Feel like getting for bedroom.
whoooo
Alamak my XM AP2 now can't connect to my network keep blinking, wifi reset also can't connect. Any bro using face same problem?
urbanathlon
Hi all,
Regards
Why will you want to buy a humidifier?
Wet air will create more air borne bacteria, more stuffs to moldy, electronics to fail, and make the person feel sticky and hot. SG RH is already around 70%.
You should be looking for a dehumidifier, it reduce to humidity to healthy level but it increases temperature at the same time.
tk
Air purifiers in online stores are selling fast.. This morning I saw some air purifiers on Lazada and Qoo10 still got stocks.. but now I check again sold out liao.. :eek:
