WussRedXLi
- Jun 15, 2001
I'm using a Sharp KC-930 and am looking to replace the filter.
Sharp website:
http://www.sharp-electronics.ie/cps...roduct-details.htm?product=FZY30SFE&cat=21090
Specifications:
http://www.lazada.sg/sharp-replacement-filter-fz-y30sfe-742902.html
Thinking of getting this as replacement:
http://www.amazon.com/Authentic-Rep...l-Treatment-9287201/dp/B00D8JGOU0/ref=sr_1_27
Think it'll work? Specifications are almost similar, just off by 0.254cm on height and width.
Thanks!
I am russian
Google found your thread when I choose right particle counter.
Thanks for your work !
Your Novita is one of the best ultrasonic humi.
In Russia sold under name Boneco Air-O-Swiss 7136
But owners not able to reach specs data
330 ml/h as max
Yes, and it makes sense if you think about it. If you do not clean the water receptacle, there would be bacteria and mold getting into the air when the water is atomised.
It's also the same for any of those wick based systems, from Air Purifiers to Evaporative Air Coolers. Actually much more difficult to clean as you'd need to dismantle a number of parts and there are more crevices. But maybe not as easy to "float" into the air as it's natural evaporation with airflow blowing across a surface.
After like 2 years, it's most probably that you'd need to replace the water wick.
Actually in SG should we be using humidifier or dehumidifier~![]()
Your kc-930 is same as my fu-z31. Dont think can fit leh.
You measure your filter and let me know? I can spare you 2pcs from taobao. 97% spec.
Sharp original is 85% H10 for your model.
Just read the spec for the A50.. Filter life is 10 years?
Edit:
Does this machine has auto speed function? ----- Found out it has auto speed function
Filter life is 12 months max, if used daily. For the HEPA part.
Activated charcoal filter is much shorter lifespan.
Replacement filters are readily available @ BEST if you afford the running costs, or Taobao has ready made units, though at 31mm thickness (1.25 inches) and not 45mm.....if you were to forgo using the AC filter. 6X cheaper and literally no performance hit if you were to use 45mm depth for the 3rd party ones.
Hence, in a way, you can change at a cycle of 6-9 months depending on haze levels (daily usage) coz it will start to smell.
Yep, got auto. But just leave it in the haze mode or medium mode....there is a Clean ION shower mode that sets the fan in HIGH for 15 mins and then reverts to previously set fan speed (eg Medium). So pretty convenient.
Never leave it in the low mode just to be silent, coz you have set it to High mode for 30 mins. It will never be able to maintain a decently low particulate matter level, esp on hazy days. Tested quite a few times before with a meter.
All APs need to operate with the Air-con, unless you can tahan the heat with closed doors/windows
Any recommended taobao links ?
i struggle to find the need of a humidifier or dehumidifier
