Air purifier?
kimsim
Suspended
Wow....that's quite sleek. Impressive.
Here's another one for your ref.. :)
http://world.taobao.com/item/448645....w5003-11904273006.1.xqQo0v&scene=taobao_shop
Wow the cost was $1.55k SGD and also 71mm hepa isn't difficult to customise?
WussRedXLi
Filters not very expensive to replace from Taobao.
That's why AX60 for the win ba. They tested PM0.1 as well for the filter (claimed > 99% filtration) from the China documentation. As well as Samsung themselves on qoo10 etc. Haven really digged to verify, maybe others could do that.
WussRedXLi
seems good, i should have choose this instead of baomi:( cheaper too 999rmb...
Be advised, there might be small issues for these stuff.
Even my Midea (so called China big brand) has slight squeaky sound when in high mode. Need some WD40 i guess.
If want cheap, just get from gumtree/carosell.
purpleberry
Just curiosu if humidifiers are causing aircons to leak? Humidity set at 50-60%.
Daikin and Mitsubishi seems to be on par? Which is the slightly better between these 2? Any Japan made ones?
WussRedXLi
From my knowledge, Daikin and Mitsubishi are not popular in SG. V v v few units.
FCU leaks due to non maintainence or too long interval last time. Try to DIY more regularly
purpleberry
Post wrong thread?
Other threads like not active haha
Mine is serviced 4 times a year but usually after 2.5-3 months it starts to leak. Currently the most oftenly used unit leaks after chemical washing just 2 months ago. I suspect piping issue but I am not an expert. I am using Starmex currently
Asakura
正常使用的话基本是一年左右就得更换的哦
现在下单咱们可以再免费赠送您一整套滤芯哦,可以保证您两年左右的正常使用
具体的还要看空气污染的程度
咱们的产品可以WiFi连接手机APP的,可以实时提示您滤芯的使用进度的
咱们现在的价格也是非常优惠的,如果您不太着急入手的话也可以等到双十一哦,咱们双十一肯定优惠力度更大的
autumni76
hmm I can't really describe it, its not anything too offensive. I don't notice it after a few minutes
I would say typical filter smell cos it is starting to smell like my Panasonic AP which hasn't had a filter changed in 3 years....
Icic.
Usually, human's nose will accommodate to most smell after awhile and get used to the smell.
I am hoping the weird smell from my AX40 from Goni is not giving out more pollutants..
