Air purifier?
cnotsniw
bloody GONI
Bloody GONI called to say LG model delayed till 26/10 and offered to 'upgrade' to Samsung AX40.
Those who bought from GONI, pls go rakuten/Qoo10 and give feedback on poor service.
Think i'm gonna cancel liao ... :s12:
WussRedXLi
Other threads like not active haha
Mine is serviced 4 times a year but usually after 2.5-3 months it starts to leak. Currently the most oftenly used unit leaks after chemical washing just 2 months ago. I suspect piping issue but I am not an expert. I am using Starmex currently
That interval sounds ok. It could v well be piping issue then.
alantcy
Just received my AX20. Very low noise, even quieter than my Philips! :)
kimsim
Suspended
Wow just received AX40, for the 1st batch of you guys ordered.
But too sad for 12pcs only :(
Now I realise why so expensive.
Incoming another 20pcs still cooking from seller :D
After next batch, you guys needs it have to do with pre-order already :)
Pre-order here via PayPal will do.
Just upfront $10 only
http://kimfilters.weebly.com/store/p1/Samsung_AX40_Custom_Hepa.html
Otherwise email me and ask for detail : kevliu78@gmail.com
Thanks regards
Kevin
Tryg2015
Icic.
Usually, human's nose will accommodate to most smell after awhile and get used to the smell.
I am hoping the weird smell from my AX40 from Goni is not giving out more pollutants..
Bro, why not just sell or give to your in laws since it's giving you so much heartache?
MIVEC525
Thanks regards
Kevin
Got mine? If anyone did not collect sms me!
kandinsky
Thanks regards
Kevin
Just to check, the DIY 300X300X25MM is suitable for DIY-ing to fit Sharp AE28, using the similar steps described by WussRedXLi on how to mod the amazon filter? Thanks!
Ok, Sharp A28 filter dimensions are 285mm x 310mm x 25mm. 1 inch thick filter
So the above Amazon H13 filter can fit. Slice up the 330mm to become 310mm (very easy coz the pleating is in the same direction) with a penknife. Scotch tape....the seal will be good.
285mm, need to use a strip of PU or LDPE foam and UHU glue to stick and cover the 5mm gap.
kimsim
Suspended
May I know your actual size?
Bigger than 300x300mm not suitable to fit, if smaller than 300x300 you can cut by own.
kimsim
Suspended
Just updated here for you guys in sequence queue :D
Can try to pm me again.
Cause only 12pcs, the rest have to waiting another batch.
ralliart_ray x1
john doe 84 x2
defytherules x2
JadziaK x 2
Linusz x 2
Asure7 x 1
Cyno505 x 2
derazor x1 (310mm x 281mm x 45mm)
JoePilot x2 (310mm x 281mm x 45mm)
meesoto x 2 (310mm x 281mm x 45mm)
Iamnagel X 2
jardine3000 x2
Whitesand x2 (310mm x 281mm x 45mm)
IDZetc x 2 pieces
WussRedXLi
Yes...300x300x25 is suitable. Just load up on the bai3 xing4 (commoner) HEPA. Rmb26.
98% eff and no effect on airflow
Buy new sharp penknife
kyuushin
Update on the no box samsung ax40 filters from qoo10
Dear customer
We receive large quantities of filters from the manufacturer, They are legit items no need to worry about the packaging. All our filters are devliered that way.
Thank you
Regards
dqwong
Correct me if i'm wrong. Won't 40-50db noise be amplified even more in a confined area like in a car? Seems too loud to me for use in car.
If your car is stationary or moving slowly, then you can hear the air purifier noise if it's on high mode, but it's not annoying kind of noise, more like a constant noise that sounds like "fuuuuuuuuuuuuuuuuuuuuu". Still able to have normal conversion but not whisper type. Also when you are on the highway, road/engine noise will exceed the noise of your AP. Just turn your car music up a notch and the AP noise will be drown out.
If the air purifier is set to Low, it's about the same noise as your engine/aircon running normally.
The clean air provided by the AP will outweigh the minor amount of noise added. Even your passengers will also feel less tired after a long journey due to the cleaner air.
NWT1978
Thanks regards
Kevin
32 pieces :D ...same packing... grab while still hot
old design of extension...still work and got safety?
kimsim
Suspended
That is ok since HDB flat can last up to 100 yrs like a tank. :D
Now HDB changed euro code, lagi 30% more steels wow
