WussRedXLi
- Jun 15, 2001
Can already smell very faint haze this morning @ 1000hrs liao.
No marnee to buy![]()
WussRedXLi said:Well, actually if one already has an air cooler in the storeroom unused and want to do that is can lah.... Just have to tape up 3 or 4 smaller pieces together. Buy from taobao, they even sell pre-filters.
Coz some of those evaporative air coolers is quite powerful for the big ones. But damn noisy.
You can try that. It's easier said than done.
They are pretty easy to cut. But now with taobao, I would not recommend that.
But nowadays you can get HEPA filters from taobao. Some are H11 grade thereabouts, some are between H12 and H13.
All will work. Just have to find a size that's bigger.
The is by smartfilters, they have tested theirs with a Dylos laser particle counter to be approx. 99.3%, so that's H12 thereabouts.
SmartAir
They tested other taobao HEPA filters, some are only like about 92% clean at the outout.
Anyway, this is one of the biggest that I can find.
hepa
All the more to consult with air purifiers gurus in this thread .
Make the expensive =>afforable .
I suppose this need to be cut too in order to fit into sharp purifier?
Not all air coolers are noisy, especially the bigger ones. They are only loud when operating at med speeds and above. The noise however is quite refined.
I have the middle unit (beige colour) model ...
At the lowest speed, the air flow is already much stronger than the Samsung AX40 at max speed. I suppose if i really want to do it, i can probably convert it to an air purifier which can cover the whole house.![]()
Will be noiser than stock after fitting in the HEPA due to added resistance though, but boy would it shift some air.
Yeah, I played before with the Mistral 200 something model and also one Honeywell biggie, damn friggin power.
Must compare apples with apples. If you'd remove the HEPA filter of the Samsung AX40, you'd find that the High speed shifts a heck lot of air too.
But actually can compare. Samsung is centrifugal, 34W. Mistral 200 is about 200W in high. If really can DIY stick HEPA, even a Blueair 650E can get lost.Will be noiser than stock after fitting in the HEPA due to added resistance though, but boy would it shift some air.
Maybe use that 5kgf 3M double sided tape to stick 4 small pieces together. I know that double sided foam tape is damn power one. Actually the normal 3M foam tapes also can, up to the individual if he wants to go overkill or not.
Get from taobao I think $50 can gao dim if consolidate with your other taobao orders.![]()
Fwah...your Europace so powerful? http://www.hardwarezone.com.sg/img/forums/hwz/smilies/eek.gif
I thought the Mistral MAC200 already super satki.
Fwah...your Europace so powerful?![]()
4pcs of the above will be too big... i dont think the filters can be cut down to size. I will probably need to look out for either 2 big pcs or 4 smaller pcs which can fit without cutting.
Look at the pic that i have posted above. The model i have is the ECO 017, the second in the lineup. Look at the unit on the right of it... that is what should be termed powerful!!! 280W, 3500 m3/hr!!!!!!!!!![]()
