Air purifier?
WussRedXLi
Thickest HEPA that I can ever find. 32mm depth. This affects the surface area/airflow resistance that the HEPA would present, and also the "longevity" of the filter. ie a 32mm filter can hold 30% more particulates and last 30% longer than a 25mm filter.
ÏÄÆÕ¿ÕÆø¾»»¯Æ÷¸ßЧhepa¹ýÂËÍøFZ-Y180SFS³ýÑÌζpm2.5diy×ÔÖÆ°üÓÊ-ÌÔ±¦Íø
WussRedXLi
I suppose this need to be cut too in order to fit into sharp purifier?
Bro, what's your Sharp A50/KC-850 HEPA size?
I think this one should fit 100%. 380mm by 240mm by 32mm.
Search for the keyword. FZ-Y180SFS (China model, I guess)
http://s.taobao.com/search?initiati...stats_click=search_radio_all%3A1&q=FZ-Y180SFS
May not be H13, but it'd do nicely as well.
invisible.hippo
Asure7
It's not easy to trigger the set into higher speeds, if you are more geared towards cleaner air, then i'd suggest put it into High speed for half an hour first. Then switch to Auto.
Just received my AX40 and put to test last night.
The light indicator is a little difficult to read since it spreads out to the sides, so a little difficult telling which icon is lighting up unless i look very closely.
In my case, the light looks like white (although its blue if i try to take a photo with my phone).
Also I noticed that in Auto mode, it is indeed not easy to trigger to higher speeds, as the sensor seems not very sensitive.
Whenever I come out of shower, my old Sharp will go into crazy cleaning mode (probably cos of the shower foam smell).
However, this AX40 remains "blue" throughout the whole night.... maybe i should try passing gas right at it just to see whether the sensor is actually working =:p
The airflow in Auto is good and silent though. It seems like its in a medium mode (not as strong as high, but stronger than low - something u cannot set). I can feel as if a mini fan is blowing at me.
WussRedXLi
Yeah man, i'd prefer a slightly higher speed than in Auto normally, but cannot. Only saving grace is that high speed is relatively silent compared to other models, but I guess still a wee bit loud for the light sleepers.
WussRedXLi
Sunday, 22 June, 2014 | 07:16 WIB
250 Hotspots Found in Riau; Haze Returns
TEMPO.CO, Pekanbaru - Head of Information Data Center and Public Relations of the The National Disaster Mitigation Agency (BNPB), Purwo Nugroho, said the Terra dan Aqua satellite yesterday had spotted 250 hotspots in Riau province.
The number has increased from the previous 80 hotspots.
"Weather is forecast to be drier and this will trigger hotspots," Sutopo told Tempo, yesterday. Hotspots were spotted in almost all regencies in the province.
Rokan Hilir has the most hotspots with 159, followed by Bengkalis (39 hotspots), Dumai (16 hotspots), Rokan Hulu (11 hotspots), Pelalawan (9 hotspots), Kampar (8 hotspots), Indragiri Hilir (5 hotspots), Kuantan Singingi (4 hotspots), and Siak (1 hotspots).
The condition is likely to trigger hotspots, especially because Riau province has entered the dry season for the next two months.
In the meantime, visibility in several regions have dropped, including in Rengat with the visibility of 3 kilometers, Pelalawan (6 kilometers), Dumai (6 kilometers), and Pekanbaru (8 kilometers).
"The threat of haze in Riau is getting bigger," Sutopo said.
Analyst from Pekanbaru Meteorology, Climatology, and Geophysics Agency (BMKG), Sanya Gautami, said the weather in Riau is forecast to be cloudy with the temperature of 35 degrees Celsius.
Sutopo also said that since April 4, matters related to the control of forest fires have been taken over by Riau Governor Annas Maamun but BNPB would continue to assist the Riau provincial government by conducting weather modification and deploying three water bombing helicopters.
"BNPB Head Syamsul Maarif has instructed BNPB Deputy Chairman for Emergency Measure Affairs to take over measures to strengthen BPBD in Riau and other provinces," said Sutopo.
RIYAN NOFITRA
WussRedXLi
bro how you use 4px saervice?
Check out this blog.
Tips for buying on Taobao from Singapore | The Elusive Sleuth
If you are afraid of security issues on paying with your CC on ah tiong websites, then use eNETS. S$1 flat fee per transaction.
PS. While you are at it, do pick up some UVEX FFP-1 masks with valve. More suitable than N95 for our moderate haze levels. The model to look out for is UVEX 3110.
µÂ¹úÓÅΨ˹UVEX3220/2220¿ÚÕÖ ÆïÐлîÐÔÌ¿¿ÚÕÖ|ÅçÆá·À»¤|·ÀPM2.5-ÌÔ±¦Íø
UVEX not likely to be cheonged, 3M KN90 masks quite likely to be cheonge.d
WussRedXLi
For my air cooler, if i can find the right sized filters for it, i probably dont even need any adhesive or double side tape. Just behind the blower unit is a panel with grids running across, top to bottom to support the HEPA filter.
Found one that's ok. Get 3pcs and cut for just one piece. Not too bad. And it's a 38mm depth filter. (you said your air cooler is 45cm by 60cm right?)
ÊÊÓÃÏÄÆÕ¾»»¯Æ÷KC-W380SW/Z380SW/C150SW¼¯³¾HEPA¹ýÂËÍøFZ-380HFS-ÌÔ±¦Íø
PS. The above HEPA filter seems to be the HEPA filter size that's used by the Sharp KC-860.
thewiseone
Yes, will have to cut one piece for this one. :s12:
It seems to be quite thick at 38mm and there's no integrated charcoal layer?
8-lane
HEPA is designed not to be be cleaned by water/solvents. Coz the fibres are supposed to hold those very fine particulates firmly. The fibres do not loose hold of the particulates easily.
Also, the PP fibre material used to make the HEPA filter also will be damaged by physical washing.
That said, you can check out some Honeywell models on Amazon. Like this one :
Amazon.com - Honeywell AirGenius5 Air Cleaner/Odor Reducer, HFD320 - Hepa Filter Air Purifiers
But do note that there is NO replacement filter available. It is also a 110V device. So if you find that after 1 or 2 washes and the design sucks coz the particulates do not come out alright, you are really out of luck.
So why risk it?
Thanks for the info :)
plasticpistola
Talking about the light - I forgot to ask how does the light work?
As right now it's blue, then is it supposed to change color or change position when the air is not clean?
Can't find any details for it in the manual :(
Asure7
I blew my bad breath directly at the sensor behind, just to test whether it's working.
It turned Red, then Yellow, Green, then back to blue (although the blue is so light it almost looks like White to my eyes).
