Amaron Battery
match89
I previously using Amaraon, but it didnt serve me too well..
called for outside service when my Amaron died and changed to GLOBATT batteries. so far 1.5years and still going good.
something
hi, my car can easy to start, but once i turn on headlight, car internal light; radio light all dim... is time to change? using amaron 60AH, about less then 1.5years...
thanks
AL5509
thanks
Drive to workshop to check if the battery is weak?
Otherwise, can self-test using a multi-meter.
If not, there might be a possibility that your alternator is not re-charging.
Hope it helps.
something
Hope it helps.
thanks bro., i found this... :o
A simple way to check if your alternaor is charging your battery is to take a volt meter. With the engine off, a fully charged battery should read around 12 volts, and with the engine running, the meter should read more around 14 volts. If you get that reading, then your alternator is charging the battery just fine. Then that means you have a parasitic draw somewhere.
To test for a parasitic draw, you need an ammeter that can read in milliamps. Acceptable draw is normally around 500-600 milliamps. If you get a reading much higher than that, say like 800-900 or more, then something is draining your battery excessively. To isolate the cause of the draw, you need to pull and replace fuses until you see the ammeter drop down to a more normal reading. The fuse you pulled that caused your current drop is for the circuit causing you the trouble, You would then have to go into that circuit and check all the wires and components for some kind of fault... things like shorts to ground and defective electrical devices. Good luck.
and this...
http://www.gardenfork.tv/simple-way-to-test-your-car-alternator
camelsback
mine is golf 7. heard from my SE say its different battery cos of the start stop function. so i cannot use regular battery ?
laiwh
any lobang for amaron battery? think my battery (reaching 3 yrs old) going to kaput soon cos I notice the longer cranking needed to start my engine in the morning. you guys normally wait till battery totally dead then change or change before it die? :s22:
sunsetbay
Moderator
Moderator
change before it dies~ u dun wanna stuck in the middle of no way then call tow truck service right~? i kena few times liao but lucky hvn't called tow truck service yet, always call friend for help 1st~ :s22:
Dragon
Administrator
Then you better change it before it dies, 3 years is long enough. :o
laiwh
yup...i kena flat battery twice liao. called for AA service both times and wasted more than 1 hour waiting.Somemore battery from AA a bit expensive leh.
Any good lobang for batteries?
CCCustom
Btw.. Which batt is better > Amaron or Bosch?
Amaron vs Bosch S4 (CA-CA) battery, go with Amaron if the required AH battery comes in the size you need, Bosch if the Amaron of the same AH is bigger sized and cannot fit.
Amaron vs Bosch S5 (AGM) battery, both are good, just go with whichever is cheaper at the time, and required AH battery comes in the size you need.
FYI: As an example, Bosch S5 45AH battery is the same size as Amaron's 35AH battery. Amaron's 45AH is larger in size. My car cannot use Amaron's 45AH battery unless I remove the battery holder and tray, and just hope that the top clamp is enough to secure the battery. I have to settle for the 35AH battery if I must use Amaron, but I bought the Bosch S5 because I wanted at least a 45AH battery.
AL5509
What is the price you found out for Bosch and Amaron(45aH)?
gnolnaix
Reply
You can try calling CY (96486555). He helped me with the battery change for my Renault car. Price reasonably cheaper than market.
PrOfAtSiR
dial a car battery.
eric- 90475437
his location at sengkang.
onsite got surcharge.
warr
Just changed to a new amaron 60ah battery for 130.
sinicker
my cheap amaron experience was from guan lee auto mr tay. $90 for 35Ah. anywhere cheaper?
jingrong
Forum is a good place to find best deal. Purchase Amaron Pro from Guan Lee at $140 (70ah) last Saturday. Happy about the price. Other shop selling $160 or more. The shop owner is friendly and honest also.:s13:
ian123
I just bought Amaron Pro 100Ah 900CCA. I paid $190. Hope it's a good price.
davpiyo
Brought 80ah Amaron Battery for $145 5 years ago, for a project using 40w solar panel at home charging mobile, powerbank and a small usb fan (Those $6 mini fan blow on face only).
There was 6 months I didn't connect the solar as I busy with work and battery still good.
