- Sep 16, 2018
Thanks for explaining, xiaofan. But I still don’t quite get it. aren’t those apps supposed to be installed in the box and thus render the chromecast irrelevant because you only use it if need to cast from phones or tablets?
Separately, even if i need to cast, i use iphones and ipads, are they compatible to chromecast? Or I should install Happycast instead?
Yes iPhone/iPad work with Chromecast for those apps supporting Chromecast. Happycast only acts as a DLNA receiver and Airplay receiver. If you use iPhones/iPad exclusively, then the importance of Chromecast is reduced since some apps also support Airplay.
As for apps, yes you can install some of the apps on the boxes and no need to cast, but based on my experiences, there is almost no chances of installing SingTel Cast and SingTel TV Go on the generic boxes. It is also almost impossible to install TVB Anywhere+ TV version. These three apps can be installed on Mi Box S or Google Chromecast 2020. This is not relevant to Chromecast function but rather on app compatibility.
All in all, good quality branded boxes are recommended for new users. But if you know what you are getting then generic boxes based on Amlogic S905X3 are also not bad. Only thing is HW quality may not be good so it will be by luck.
I have bought many boxes to play with before getting the Mi Box S. After getting Mi Box S, most of my other boxes are collecting dust, except an S905X2 based box (TX5 Max, Tanix OEM version). One of my generic box, Tanix OEM TX6, already died after one year of light use.
