Android TV Box
jkohlc2
I just realised chromecast ultra is a lot older than regular chromecast :eek:
Posted from PCWX using Oneplus 8T
mib500
Most likely okay but please check with your IPTV vendor.
If the IPTV apk can be installed under Mi Box S, most likely it will be okay under Google Chromecast 2020.
If not working under Mi Box S, then it will not work either under Chromecast 2020.
Noted with thanks!
DentYL
help on hk drama apk for android tv box
Need some help.. need some good and simple free apk for my mum to watch her latest hk drama on android box.. jins365 had been useful.. but recently cant be watch anymore.. adrama is not updating also.. 99kubo dun seems able to full screen for her.. any recommendation??? old ppl.. need something user friendly.. thanks in advance..
Just Me
Just apply for tvbanywhere+ loh. I think only about $6 a month. Comes with 5 live channels as well (12 month sub). Drawback is you need a compatible tv box for the Android TV version
https://shopee.sg/product/287909988/5158377132?smtt=0.278873-1608960366.9
List of supported devices : https://staticweb.tvbanywhere.com/certified-android-TV-list.pdf
Sent from Xiaomi MI 9T PRO using GAGT
gregory_choo
uninstall the jins365 and install this working version.
http://tiny.cc/today216f
better for old people to stick to the same app.
magixz
Thank you for your patient guidance, xiaofan. I do have a chromecast 1st gen, bought years ago but never really used it. I took it out to try and i can now cast NHK world onto my tv. Which is nice. Couldn’t do it previously.
Does the 1st gen function like a tv box or it is only for casting? I am thinking while i ponder about what tv box i wanna get, i can practice on this 1st gen chromecast as a tv box? Any suggestions on apps or apk i can download or install to begin my practice?
I have a First Gen too, seldom use cos when you use youtube playing on screen there are ADs, I rather use a cheap TV box n use Smart Youtube TV app.
magixz
I use my old 1GB RAM box, factory reset, disable all google services and install Aptoide TV Sideload the apps i want, SMART youtube TV, Jin tv, box is very much useable now actually
gregory_choo
actually most of the 6 year-old, s805 boxes with 1GB RAM are still running well with most of the popular media apps.
magixz
I got my old S805 up too, but my sister gave me a RK3229 1GB box which is good enough, I mod cooling, use USB FAN, Bigger heat sink n new thermal compound, now box does not emit heat at all under load.
DentYL
Just Me
Thanks!! that helps alot!!!!
Jins is also one of my favorite vod apps but it's harder to search because it doesn't support english names and if you need to reinstall all your watched and favorites will disappear
godspeed1980
wad other app do u recommend?
TimsTom
Hi, does anyone face a similar error as me?
When i use a broswer(both firefox and chrome) to try play/stream a video, there will always be error to play it(youtube on broswer can play video).
On ipad and android phone is can play, but on my android box there is this error. There is also a sentence saying maybe is Adblocker that affect the playback, but I didn’t download any (except surfshark vpn cleanweb function but i was not connected to vpn when i try to play video).
3bLuGyy
gregory_choo
3bLuGyy
why use browser to play? there are many dedicated video apps for android boxes.
C32B
Just curious about casting to Chromecast. Is there a distance range just like Bluetooth ? I tried casting at my MIL's house old 3 room HDB with long kitchen. The TV is beside the main door and cast from the kitchen entrance. It cast awhile, after that some distortion come in and then with pic no sound.. Lol
Sent from OnePlus GM1910 using GAGT
