I brought a Xiaomi 4k TV stick.what's the difference between Mecool KM2 and KM2 Plus? it looks like there's not much of a difference?
main use:
wired connection
youtube
iptv
starhub tv+
plex
no need for netflix, disney+ all those sub apps.
these 2 apps wil check whether they are installed on ub box. they will not run if hardware is not from ub.How do you sideload ubox app like uplive or upmovie onto tv?
uplive do work despite the loading take sometime, u will need a VPN to bypass the check.How do you sideload ubox app like uplive or upmovie onto tv?
ub will be closing soon if what you said about ublive is true. first time hear 'people' say vpn can bypass hardware check.uplive do work despite the loading take sometime, u will need a VPN to bypass the check.
i dont run uplive on the TV instead i run ott player and built my own iptv and the setting to hardware video player and as for VOD i have 2 option. If you do know that u can setup web VOD from ubox and if u could convert web to apk and installed into the tv. the other option is i use muvod mostly asian movies and onebox for other movies. And it will be good to plug in a mouse into the TV for ease of access.
pm me if you do want to know better the details
you need to have google certified box if you want to play netflix, prime, disney....Hi,
Any recommendations for decent android box.
Requirements: Youtube, netflix, Amazon Prime Movies and install one APK for streaming.
Previously had Minix U9 for 5 years and now it is gone.
Want something good that can last for few years and ok upto 150 sgd.
any good recommendations please?
thanks
just do a simple factory reset then your box is as fast as new.Thanks. the previous minix box became very slow and for loading youtube also took 3-4 mins and then to navigate also very slow. any suggestions for this?
The only app i want to sideload is HomeLiveTV.
consider buying a new tv if you got a budget to spend $150 for a box and to add another $650 u could get a prism + 55" android tv with all the support for your Requirements: Youtube, netflix, Amazon Prime Movies and able to sideload third parties apk.Hi,
thanks
No idea, but SVI Cloud 3Pro not bad, but can't seem to find a way to use hanyu pinyin as input for chinese characters in search.Svicloud 8p good?
Thanks. How to find out if the APK i want to sideload is compatible with chrome cast? thanksconsider buying a new tv if you got a budget to spend $150 for a box and to add another $650 u could get a prism + 55" android tv with all the support for your Requirements: Youtube, netflix, Amazon Prime Movies and able to sideload third parties apk.
however, if you do want to keep to your budget then no need so much a google chome cast TV will support
Requirements: Youtube, netflix, Amazon Prime Movies, however to sideload apk were be a little technical but can be done cost u $70 or less.
you cannt until u try, what the name of the app. i can check it outThanks. How to find out if the APK i want to sideload is compatible with chrome cast? thanks
