Android TV Box
firestyle
There could be several problem.
1 it could be over heated device.
2. there is a malware that automate the shut down
3. There could be a automate shutdown within your device which was schedule to shut down at a certain time.
If in the day time it didnot happen to shut down then the over heat issue may not be the cause.
it is probably a shedule time shutdown.
thanks for the analysis.
i have kept the 2 tv boxes pretty weight and only stalled 2 common media streaming apps. so the likelihood of malware is quite low. heat issue is quite unlikely too.
if true, then i wonder what is it that trigger the schedule shutdown since mibox s doesn't have this functionaliy ootb.
another low possibility that i suspect is if whether it is my tv that cause it to shut down due to the absence of activity...
Philippng
Yes, that is also a possibility. I have seen shuting down the box, it shut the tv too. So the same can happen on the tv too. check it out and i like to hear if that is the case, then i learn something again.
gregory_choo
turn off cec, see whether it helps
do it on both tv and box
promfret87
Hi, for the malaysiatv app, do I need a mouse to use it? Tried to run it but I can't see the cursor anywhere when using a controller
Vanyel
recently my dad's ub box the China cctv and satelite channels all unwatchable is it shutdown from china side?
any workaround?
gregory_choo
any workaround?
install emotn store on the box. then you can find 5 to 6 good tv apps for china cctv
just need to enter sharecode 545497
Shinn88
Hi all
May I ask if for recommendations for tvbox or app to have/download
My elderly parents wants to watch live tv. Taiwan channels mainly
Currently using a old svi cloud tv box. The live channels can't load already
My tv is a 4 year old Xiaomi, china global set I think. It's a smart tv but unsure if it's google powered
gregory_choo
Hi all
try 星视界, 海星tv , 野火电视,or cloudTV.
all xiaomi tv are using either AOSP andriod, or andriodTV/googleTV. can run most of the android apps.
the easier way to install these apps is to go through emotn store.
run emotn store, key in sharecode 545497.
gregory_choo
Can install starhub tv+ on svicloud?
no. svicloud is pirate box. only google certified box can.
but google certified box is cheap, if you can spend $200 to buy a scammy box, you should be able to get certified box. around $60 can buy a reasonably good one.
Shinn88
Thanks for the answers. Really appreciate it. May I know where to find emotn store. Or issit I need install the APK file. Sorry. Parents always hoarding the tv. I rarely get to use so I don't rlly know
gregory_choo
google for emotn store. download the apk file, save to thumbdrive, bring over to tv to install.
ckfreeblue
Hi guys, would like to kindly check regarding this. Bought a Xiaomi TV Box S (2nd Gen) off Shopee, how come the timezone does not include Singapore?
And I also installed StarHub tv+ app as I have the subscription but if I try to watch it via the Xiaomi box, it doesn’t think that I am a subscriber. What seem to be the issue?
gregory_choo
what timezone you set ?
ckfreeblue
Since there’s no Singapore option available, can only set it to alternative GMT +08:00 options (Hong Kong, Kuala Lumpur) etc. Any fix for this would be greatly appreciated.
Arandalo
Don’t think there’s ever a Singapore option available all these while.
ckfreeblue
I see, that’s weird, does it affect usability? On a separate note, I can log in to StarHub tv+ on my mi box s gen 2, but it can’t seem to detect my subscription even though I’m logged in. Is it a known problem?
