Anybody using Singtel Mesh?
Singtel
Suspended
Hi ahkrong,
Has the connectivity issue been resolved? If not you can PM us your Singnet ID and contact details and we can get our fibre team to try to help.
Thanks.
Sorry but I'm a noob. How do i reduce the bandwidth? Or is there a step by step that i can reference to? Thanks a million.
Sent from mai dua karchng using GAGT
Singtel
Suspended
Hi negativzero,
Just to clarify, are you using AirTies 4920 or 4930?
Kindly PM us your Singnet ID and contact number and we can get our fibre team to look into your request.
Thanks.
Need the latest firmware for AirTies. Can anyone send??
Weaboo
was looking at the askey thingy... so if i have my pc in my room while my fibre is in the living room, can i install one of the askey node in my room then plug my ethernet cable into it to use internet on my computer?
hows the speed like?
Giroman
Currently using AirTies 4920.
Realise that there is no guest wifi network feature for AirTies 4920?
Did some research and found out that guest wifi network is available on the Askey AP5100W.
Both AirTies 4920 and Askey AP5100W are $10 per month.
Have anyone tried calling Singtel to see if it's possible to swap the AirTies 4920 to the Askey AP5100W?
Weaboo
bump my question up
Singtel
Suspended
Hi Weaboo,
If we are understanding you correctly, your intended setup is:
Singtel ONR ---wireless--> Askey AP5100W Mesh (1st node) ---Ethernet cable--> desktop/laptop
Based on such a setup, our broadband product team notes that you should be able to enjoy up to 1Gbps speeds in typical scenarios. However, do note that actual performance is dependent on a multitude of factors including but not limited to:
- distance between router and mesh node
- walls in your premises
- cable type used in your wired connection
- potential interference from other WiFi networks in the vicinity
Hope this helps, thanks.
bump my question up
was looking at the askey thingy... so if i have my pc in my room while my fibre is in the living room, can i install one of the askey node in my room then plug my ethernet cable into it to use internet on my computer? hows the speed like?
Singtel
Suspended
Hi Giroman,
There is the guest WiFi network feature on AirTies 4920.
Here are the instructions that you can follow to set up GUEST SSID on AirTies 4920:
1) For WLAN 1 (2.4 GHz):
a. Advanced Settings
b. Click on Advanced Setup
c. On WLAN 1 (2.4 GHz) tab:
i. Enable “AirTies_Air4920_GUEST”
ii. Select Security “WPA2”
iii. Show Password: You can change the Wireless Password here.
iv. Click Save
2) For WLAN 2 (5 GHz)
c. On WLAN 2 (5 GHz) tab:
iv. Click Save
Hope this helps and do let us know if you can successfully activate the feature. Thanks.
Weaboo
Hi Weaboo,
yes
but does the askey mesh thingy have the ethernet cable to connect to my pc in the room? that was what i am asking
Giroman
Hi Giroman,
iv. Click Save
iv. Click Save
Hi Singtel,
Do you mean the following below?
Clients connected to the AirTies_Air4920_GUEST wireless network are able to access the AirTies Management page and the Singtel WiFi Gigabit Router AC Plus Management page.
This should not be the case right? There should be some form of network/VLAN segregation to prevent clients on the guest network from interacting with clients on the main wireless network.
Singtel
Suspended
Hi Weaboo,
Our Askey AP5100W comes with one Ethernet cable in the box intended for connecting to the router.
To connect additional devices, you can purchase an Ethernet cable with an FJ45 connector and we suggest a CAT5e/6 cable for better performance.
yes
Singtel
Suspended
Hi Giroman,
Our broadband product team confirmed that the network segregation feature that you asked about, is yet to be available on the AirTies 4920 currently.
Thanks.
Hi Singtel,
Poklan Kulafu
There is a new Mesh in the market which is the Aztech WMB250AC
It has four extra LAN ports that you can able to use in case you need additional LAN connections
As installed one to my boss house, the speed is really good and the connection is stable
I think Aztech is trying to redeem themselves that is why they launch a good product:s13::s13::s13:
orangeman
Just tried the asked mesh. But am not sure of the following.
1) first mesh have to be connected to the router?
2) second mesh can i plug into my room data point?
