RSKeisuke
- Aug 26, 2000
Need a little confirmation before I sign up for the Askey mesh pair.
My current setup is FTP->ONR->AC1900->Desktop PC (in room)
The link between AC1900 to my PC is a ethernet cable.
I would like to get singtel mesh and connect in the following manner
FTP->ONR->AC1900->1st mesh(right next to AC1900)->2nd mesh(MBR)-> Desktop PC
I will utilise the backhaul LAN ports on the Askey to connect the 1st mesh to 2nd mesh using physical ethernet connection, also ethernet connection between 2nd mesh to desktop PC.
1) Is the above the correct way to set up?
2) The AC1900 already has its SSID, with the addition of mesh wifi devices, do I need to disable the AC1900 own wifi access point? Or do they work together fine under a single SSID?
