[CASE] Phanteks Enthoo EVOLV ATX
zhane
If i want to maintain H100iv2 on top and its 2x fans and the rear fan as exhaust, would changing the stock 2xinput 140mm fans to 3xCosair 120mm AF120 helps?
I was calc the CFM.
2x stock 140mm = (82.1x2) = 164.2CFM
3x cosair 120mm = (52.19x3)=156.57CFM
Dont seem to be able to generate greater airflow by doing this..
Any comments?
*adiBOY
I was calc the CFM.
Any comments?
You can change to 3 x corsair ML120 Pro fans.
HungryPillow
Received the call today from Corbell and ordered the tempered glass version on Lazada... still a few pieces left if anyone else is interested :)
tremor
Yea corbell updated that stocks will be in on Thursday
HungryPillow
Hey guys,
I just got an Enthoo Evolv Tempered Glass and could really use some help with how to connect all the fans.
Right now I've done the following:
The 2 stock front fans are connected to the PWM hub on the case
The PWM hub on the case is connected to CPU_FAN on the motherboard (Asus Z77 Sabertooth)
I have a H100 radiator on top with 2x Corsair ML120 Pro LED fans. The 2 fans are connected to a Y splitter which is then connected to CPU_OPT on the motherboard
The rear exhaust fan is a Corsair ML140 Pro LED which is connected to CHA_FAN3 on the motherboard
Right now when I turn on the computer I get a CPU FAN error and the two fans connected to the radiator do not work at all. All the other fans seem to be working OK since I can see them spinning.
My main question is what would be the ideal way to connect the fans so that everything works well together?
I've also purchased a RGB lighting kit from Cablemods which I have not tried to setup yet. Does anyone have any experience with this kit and know the best way to set it up in this case? I'm not sure if you can get the kit to sync together with the lighting on the front and power button of the case...
Thanks and sorry for asking so many things at once :D
xSyntz
Hey guys,
Think you forgot to connect the Corsair pump header.. Don't see you mentioning it anywhere. Connect it to CPU_FAN header and set to 100%. This is probably why you are getting the error...
CPU_OPT will mimic CPU_FAN speed. Unless you want your radiator fans to always be at 100% I'd suggest connecting to PWM hub or another chasis fan header
PWM hub connect to chasis fan header instead of CPU fan header
Not sure about LED strip.. Only know it is compatible with AURA supported boards. The Phanteks case and Phanteks LED strip both have a locking style connector. Hope this is helpful.
