[CASE] Phanteks Enthoo EVOLV ATX
royfrosty
Theres only 2. One for chassis LED. One for Phanteks LED which is purchase separate.
shanli
Weird, for my phanteks led wire it is not connected to the hub 12v. For mine the chassis led and phanteks led is linked tgt.
HungryPillow
There should be 3. Check around the small wires that are bundled together mine were hidden in there. It should be 2 small funny looking connectors for the Phanteks RGB LED, 1 SATA for the case LEDs, 1 SATA for the PWM fan hub. Look at page 10 of your manual.
I plugged in both SATA and didn't use the RGB LED connector since I bought those from Cablemods.
shanli
Yup I think there was a confusion hahaha. Actually the funny looking connectors for the phanteks RGB led is linked to the sata for the case I believe.
The sata for the PWM fan hub when I pluck it out my fans are still working thats why I find it weird. Or is it because my fans dont take too much current/voltage compared to other fans.
HungryPillow
Yea I did that as well and thought it was the correct way to set up the fan. I was told that's incorrect and without the SATA 12v cable connected, your case PWM hub is just acting as a Y splitter and the fans are regulated by voltage.
I have a question for other Tempered Glass owners. Is the HDD LED supposed to flicker with HDD activity? I have the cable connected to my motherboard and the LED on the front panel (I assume this is the HDD LED?) is permanently on... it's the same as the power button LED.
xSyntz
Yeah the white ring around the LED control button supposed to flicker with HDD activity. Maybe check your front panel headers are connected correctly
HungryPillow
Ahh did not realize the HDD LED is from there... I thought it was the LED bar on the front panel.
I had the HDD header plugged in the wrong way to the mobo, I flipped it and now it works. Is there any way to change the color for the HDD LED or is it just white? Thanks!
xSyntz
Nope, only white. Only able to change color for power button and that thin line on the front
shadow84
If you are good in soldering, you can remove the LED and replace with another coloured LED.
LegendZenify
Since it's white (and if you lazy or dunno how to solder), you can just cover the led with a thin layer of nail polish.
This method works best on white leds. :s13:
Op_Valkyrie
Can this case fit 360 rad at the top and 360 rad at the front without modding?
Possible.... but going to be shoehorned.... :s22:
royfrosty
You can put 2x360mm. But you got to make sacrifices. Got to make do with res pump combo, find a way to do a horizontal res.
Just like the pic above.
Also you will have a hard time with your rest of the pcie slots. May not be able to use in future.
For my case, i still retain the 360mm slim at the top, 240mm in front.
I put a pump at the bottom, and i have space for a res. Doing so, i have access to all my pcie slots.
HungryPillow
OK not a big deal :)
haha not good at soldering and don't mind it being white
lol thanks good to know :s13:
Demonbecks
hi guys need some help, i'm trying to install 3 x 120mm fans in the front. How do I keep them in place? There are no screw holes for the 120mm fans, only for the 140mm fans. Do I have to buy nuts to keep them secure?
NeonX
I just did that today lol. I screw the fans in with short screws from the inside. Bear in mind the lowest fan bottom screws will require u to remove the 3.5 hdd cage to access it
Sent from Samsung SM-G930F using GAGT
