[CASE] Phanteks Enthoo EVOLV ATX
KeYoKe
i havent got e case n cooler yet.. will do so when i get my new rig later in e year.. will be using e fans that phanteks n cryorig provide with e casing n cooler
yeah i know positive air flow keeps e dust out, but only if there are filters right?
hmm DEMC? do they sell filters for e phanteks?
edit: i also see a lot of bros here using e casing with AIOs like corsair, so want to know how they have configured their fans too
I dont use corsair cos i find they are overpriced so i use id cooling frostflow 240l.
My config is:
2 x front intake GT AP15
2 x top 240mm exhaust rad GT AP15
1 x rear 120mm exhaust GT AP15
evq
Your bluray drive inside ur case???? Wah then if u wan to put disc into the drive u need to take out the side panel ahh???
Yeah. I need the bluray drive to rip my bluray disc collection. Yes open the side panel to access
Gr3yham3
hmm how come must rip blu ray? i got a big collection of blu ray but never thought of ripping leh..haha..
anyway, e airflow in ur rig is considered negative since exhaust more than intake?
so far any dust or temp probs?
Gr3yham3
My config is:
means u also got more exhaust than intake ? hmm seems like lots of bros here also using e same config.. but how come ur fans 120mm? e stock 140mm fans by phantek not good?
evq
No dust. 2 intake & 3 out. If u consider the 2 out which have to pass through the radiator, then the 2 out may not be able push that much air out.
Cos I steam my movies from my nas, thus I ripped them into mkv files
Gr3yham3
hmm icic... well so long as most of e bros here who have are using this casing are having no probs, i guess i will just follow suit too
anyway, does anyone know where i can preview all 3 colours in person for e casing? all look damn nice la
evq
go for the grey. I using the silver, but now prefer grey.
NeonX
Can always set a custom fan curve to maintain a positive air pressure scenario. Shouldn’t be that complicated
ZrE0_Cha0s
their website already have those color already :s22:
Gr3yham3
hmm can share or PM ur settings? will lowering e AIO fans speeds cause problems to e cpu cooling?
NeonX
What I do is run my 3 front intake at 80%
Aio to exhaust untouch, back 120 exhaust cap at 50%
KeYoKe
I find the 140mm provided by phanteks is quite well built and sturdy. I am a GT siao. So thats why all i change to GT
KeYoKe
Wont cause a problem. Plug pwm of fan hub to cpu fan 2 of the mb. When cpu temp goes up then the fan speed goes up higher lor. Use custom fan curve so can reduce noise of the fan when ur cpu nt under load
Gr3yham3
Yes, not using any phanteks f 140
icic.. dun think i will be changing e fans but will try to fiddle with e fan settings... so all ur fans are connected to the PWM, while e pump is connected to e cpu fan 1?
gld998
buying all your 140 mm phanteks fan at 10 each if nvr use b4.. LOL :D
Abit weird using fractal design R2 140mm fans on my case
proud Phanteks Enthoo Pro owner here...
NeonX
No way haha, the phanteks fan are excellent, just a bit noisy for my taste
