[CASE] Phanteks Enthoo EVOLV ATX
KeYoKe
Finally completed last piece of my puzzle with MSI GTX 1070 Gaming 8GB
zephyr11
this casing sibeh swee, before i got the R5, i thought about this, but that time like immpossible to get, so bo bian, get R5. now like regret, nothing wrong with the R5, just not as swee....
Gattberserk
If u want smth more simple, u can try the enthoo pro m. Its cheaper but it has most of the perks that evolvo atx have, except didnt feel as solid or high class, but still it damn good (especially the full acrylic)
Mclairs83
same here.
wanted to get but not available. end with R5. Now just LPPL and suck thumb not as if i always look down and admire my casing.
NeonX
icic.. dun think i will be changing e fans but will try to fiddle with e fan settings... so all ur fans are connected to the PWM, while e pump is connected to e cpu fan 1?
i'm using a rog board, so my pump is connected to the waterpump header. All the fan headers on my board are pwm
FlushX
I've tried using the waterpump header. but ASUS board always prompt me error when I have 0 fans attached to the CPU fan header.
NeonX
i plug pump to waterpump header, for my situation i'm running 2 ML Pros on my h100i v2, so i plug both the ML Pros into CPU and CPU opt. I don't control using corsair link cause troublesome. Everything run from fan xpert is easier for me, no need to config both software.
Or you can disable cpu fan warning, but not very recommended for obvious reasons :s22:
