deepblue_82
- Oct 23, 2007
ok thanks i dig carousell mb + cpu is cheaper... i will keep digging for ram and mvme and psu then i am good
hi guys, planning to get the following
Coolermaster NR200P Max i5 13600K+ Asus Strix Z790-I or Asus Strix B760-I Read that the B760-I will require undervolting to keep temps low and the 2nd M.2 will be limited as there isn't enough lanes, is that true?
Asus Tuf Gaming RTX4070Ti OC WD Black SN850X
Crucial P5 Plus
only gonna use it for gaming and day to day net surfing
King fury beastwhat ram did you pick? Gonna get the same case with a similar setup
Thanks!King fury beast
cheapest ddr5 around
Asrock considered quite cheap liao for both the X670E and B650E lineup, if you find the X670E Steel Legend too expensive can drop to say, B650E PG Riptide lohShould i get x670e or b650e?
The x670e still very expensive now
Looking for asrock steel legend x670e now for my 7600x
Probably a 13600k, make sure you get the 5600MHz version of Fury Beast cause they are Hynix die (older ones probably M die, newly manufactured ones are A die)Thanks!
should I get a 13600k or 7600/7600?
pairing it with a 4070ti
| Bizgram | Tech Deals | PC Themes | Laser | Infinity | Fuwell | Dynacore | Tradepac | ||
| AMD 7800X3D | |||||||||
| ASRock B650E PG RIPTIDE WIFI AX ($404) | 1207 | 376 | 1059 | ||||||
| Asus ROG Strix B650E-F Gaming Wifi ($508) | 1303 | 480 | 1174 | ||||||
| Gigabyte B650E Aorus Master ($694) | 1477 | 705 | 659 | 1334 | |||||
| CAS | 32GB | ||||||||
| Corsair Vengenance DDR5-6000 | C36 | 265 | |||||||
| Corsair Vengenance DDR5-6000 | C40 | 253 | 319 | 459 | |||||
| ADATA XPG LANCER 6000 | C40 | 239 | 268 | ||||||
| ADATA XPG LANCER RGB 6000M C30 KIT | C30 | 308 | |||||||
| Kingston Fury Beast RGB 6000MT | C36 | 292 | |||||||
| Kingston Fury Beast RGB 6000MT | C40 | 283 | |||||||
| G.Skill Flare X5 AMD Expo 6000mhz | C32 | 230 | 399 | 239 | |||||
| G.Skill Flare X5 AMD Expo 6000mhz | C36 | 349 | 216 | 215 | |||||
| G-Skill Ripjaws S5 6000mhz | C30 | 217 | |||||||
| G-Skill Ripjaws S5 6000mhz | C36 | 219 | |||||||
| G.Skill Trident Z5 RGB 6000mhz | C32 | 527 | |||||||
| G.Skill Trident Z5 RGB 6000mhz | C36 | 268 | |||||||
| G.Skill Trident Z5 RGB 6000mhz | C40 | 342 | |||||||
| G.Skill Trident Z Neo AMD DDR5-6000 | C30 | 285 | |||||||
| G.Skill Trident Z Neo AMD DDR5-6000 | C32 | 449 | 529 | 279 | |||||
| G.Skill Trident Z Neo AMD DDR5-6000 | C36 | 399 | 265 | 260 | |||||
| Asus TUF-RTX4080-O16G-Gaming | 1985 | 2028 | 2099 | 2099 | 2029 | ||||
| Asus ROG-STRIX-RTX4080-O16G-Gaming | 2156 | 2118 | 2269 | 2269 | 2189 | ||||
| Asus ROG-STRIX-RTX4080-O16G-White | 2382 | 2599 | 2489 | 2489 | 2269 | ||||
| Gigabyte N4080EAGLE-16GD | 1945 | 1919 | |||||||
| Gigabyte N4080EAGLE OC-16GD | 1978 | 1999 | 1839 | 1955 | 1955 | 1845 | |||
| Gigabyte N4080GAMING OC-16GD | 2028 | 2059 | 2029 | 2015 | 2015 | 1899 | |||
| Gigabyte N4080AERO OC-16GD | 2065 | 1959 | 2095 | 1965 | |||||
| Gigabyte N4080AORUS M-16GD | 2150 | 1979 | 2169 | ||||||
| Gigabyte N4080AORUSX W-16GD | 2230 | 2260 | 2169 | ||||||
| MSI RTX4080 Ventus 3X OC 16GB | 1850 | 1868 | 1988 | 1988 | 1849 | ||||
| MSI RTX4080 Gaming X Trio 16GB | 2020 | 1958 | 2058 | 2058 | 1930 | ||||
| MSI RTX4080 Suprim X OC 16GB | 2198 | 2198 | 2149 | ||||||
| HYTE Y60 | 280 | 275 | 302 | 299 | 278 | ||||
| Deepcool AK620 ZERO DARK | 101 | 100 | 99 | ||||||
| MSI MPG A850GF 850W/80 Gold | 182 | 179 | 175 | ||||||
| MSI MPG A850G 850W/80 Gold PCIE5 | 260 |
fierce, 7800x3d haven release they got the price liao, the distributor might not even have it i think or able to announce yetHello everyone, looking to build a new rig for playing Diablo 4 at 1440p maximum settings.
Will probably wait for the AMD 7800X3D chip since it seems to be great for gaming.
I've listed the parts I mainly require for the build, but I'm not sure which to get; should I get them separately or all from one shop? Since for some parts the prices can vary by quite a large margin.
Thank you!
Bizgram Tech Deals PC Themes Laser Infinity Fuwell Dynacore Tradepac AMD 7800X3D ASRock B650E PG RIPTIDE WIFI AX ($404) 1207 376 1059 Asus ROG Strix B650E-F Gaming Wifi ($508) 1303 480 1174 Gigabyte B650E Aorus Master ($694) 1477 705 659 1334 CAS 32GB Corsair Vengenance DDR5-6000 C36 265 Corsair Vengenance DDR5-6000 C40 253 319 459 ADATA XPG LANCER 6000 C40 239 268 ADATA XPG LANCER RGB 6000M C30 KIT C30 308 Kingston Fury Beast RGB 6000MT C36 292 Kingston Fury Beast RGB 6000MT C40 283 G.Skill Flare X5 AMD Expo 6000mhz C32 230 399 239 G.Skill Flare X5 AMD Expo 6000mhz C36 349 216 215 G-Skill Ripjaws S5 6000mhz C30 217 G-Skill Ripjaws S5 6000mhz C36 219 G.Skill Trident Z5 RGB 6000mhz C32 527 G.Skill Trident Z5 RGB 6000mhz C36 268 G.Skill Trident Z5 RGB 6000mhz C40 342 G.Skill Trident Z Neo AMD DDR5-6000 C30 285 G.Skill Trident Z Neo AMD DDR5-6000 C32 449 529 279 G.Skill Trident Z Neo AMD DDR5-6000 C36 399 265 260 Asus TUF-RTX4080-O16G-Gaming 1985 2028 2099 2099 2029 Asus ROG-STRIX-RTX4080-O16G-Gaming 2156 2118 2269 2269 2189 Asus ROG-STRIX-RTX4080-O16G-White 2382 2599 2489 2489 2269 Gigabyte N4080EAGLE-16GD 1945 1919 Gigabyte N4080EAGLE OC-16GD 1978 1999 1839 1955 1955 1845 Gigabyte N4080GAMING OC-16GD 2028 2059 2029 2015 2015 1899 Gigabyte N4080AERO OC-16GD 2065 1959 2095 1965 Gigabyte N4080AORUS M-16GD 2150 1979 2169 Gigabyte N4080AORUSX W-16GD 2230 2260 2169 MSI RTX4080 Ventus 3X OC 16GB 1850 1868 1988 1988 1849 MSI RTX4080 Gaming X Trio 16GB 2020 1958 2058 2058 1930 MSI RTX4080 Suprim X OC 16GB 2198 2198 2149 HYTE Y60 280 275 302 299 278 Deepcool AK620 ZERO DARK 101 100 99 MSI MPG A850GF 850W/80 Gold 182 179 175 MSI MPG A850G 850W/80 Gold PCIE5 260
RAM I suggest Kingston Fury Beast 5600 if you willing to tinker a bit, Hynix A die so it has the most overclocking headroom, otherwise can get the 6000 if you willing to pay moreGuys, planning a small form factor build. Planning to use it for some Ultra Wide 2k gaming, work (mostly excel), surfing of the internet and watching videos.
Case: Cooler Master NR200P Max
CPU: Ryzen 7700 or 7700x (Not sure if i should go for the X version, what do you guys think)
Mobo: Asus ROG STRIX B650E-I Gaming Wifi
GPU: Gigabyte 4070 Ti GAMING OC 12G (Have purchased this and can't be changed)
Ram: DDR5, 32GB, Need RGB.Still undecided here
Storage: 1 or 2TB, preferably Gen 4 NVME
Cooler: 280mm AIO (Included in case)
PSU: V850 SFX GOLD 850w (included in case)
Would need some suggestion on compatible ram and storage.
Also, would it be cheaper if i buy some of the parts from SLS (From Dynacore etc), or would it be cheaper if i just get them from shopee, lazada, amazon etc? Not in a rush to build it.
TIA
if just gaming, either will perform about the same. see which combo less expensive with appropriate memory: u can get away with slower cheaper 5200c40 ddr5 for intel, but amd side need fast tight ram (preferably 6000c30) which costs more. 7600 consumes quite a bit less power though and comes with a box cooler, so u can skimp on the cooler if u want.should I get a 13600k or 7600/7600?
i would have suggested going for a tecware fusion with a way cheaper matx mobo (strix b650e reallyGuys, planning a small form factor build. Planning to use it for some Ultra Wide 2k gaming, work (mostly excel), surfing of the internet and watching videos.
from sls u are buying local stock parts which are generally more expensive than buying export set from say amazon. some shopee and lazada listings are also from sls shops so pricing may not be very different from sls. u can get some really good deals for ram and ssd on amazon, and for ram especially u can get kits with even tighter timings than what is available locally.Also, would it be cheaper if i buy some of the parts from SLS (From Dynacore etc), or would it be cheaper if i just get them from shopee, lazada, amazon etc? Not in a rush to build it.
good effort. personally i would get them separately as u mentioned the prices do vary from shop to shop, so there can be significant savings. i would also like to suggest a few more things for u to consider. since u are looking at getting a x3d chip, ram selection is less of a worry, so u can drop down to slower kits and still get >95% of the performance for a lot less money. i see u are also targeting 4080 level of performance, so u can take a look at 7900xtx cards which should perform similarly for cheaper, got quite a few models near the $1600 mark (gb gaming oc from bizgram is under) so u stand to save $200-300 from the cheapest 4080. they also dont require the pcie5 power connector so u can save money there too. finally, if u can find the thermalright peerless assassin 120 for cheaper (usually around $80), that is the better pick.Hello everyone, looking to build a new rig for playing Diablo 4 at 1440p maximum settings.
Don't mind me asking. Any reason u buying a new rig? Seems like the pc u having is still very very new and goodAfter much surfing Amazon, Carousell, Lazada in the last 2 weeks, I got the following:
Motherboard - b650 Aorus elite - $395 (Lazada)
CPU - TBC to collect tomorrow either 7700x or 7900x or 7950x still undecided
Sapphire Nitro 7900xtx $1550 (Carousell)
Gskill Trident Z5 32GB 6000mhz CL30
SN850x 2TB
Formulamod PSU extension cables
Total USD 385 (512 SGD) (Amazon US)
SN850x 1TB - $135 (Carousell - buy because my Amazon expected delivery for NVME was month end, but then it updated again to end of the week. Wasted money)
4 x Arctic P14 - $64 (Carousell)
NZXT H7 Flow - $170 (Lazada)
Deepcool LS720 - $159 (Carousell)
Psu - reused
$2590 spent so far - I was hoping to not cross $3K.. but I guess it will happen
not sure if I saved any money overall compared to Simlim but I enjoy shopping online hahaha
now time to sell my 5600x RTX3070 PC which I lugi a lot since I bought during the peak of computer prices in Covid times.
Itchy backside.. bought the new gpu but motherboard had some cables blocking the gpu so couldn’t install.Don't mind me asking. Any reason u buying a new rig? Seems like the pc u having is still very very new and good
How much did you pay for your ram?Itchy backside.. bought the new gpu but motherboard had some cables blocking the gpu so couldn’t install.
140+ usdHow much did you pay for your ram?
