KleoZy
- Jan 1, 2000
Putting tons of fans is one matter, knowing how the airflow works, is another.This case got no airflow ah? But I see it has lots of fans...
I don't want liquid cooling as I don't want to maintain it in the future.
I want 4080 to play D4 with RTX enabled.
The difference between them also 200-ish, might as well get the 4080.
I have tested numerous of O11Ds cases and all react the same. no matter which fan direction, O11Ds are meant for Water cooling or Liquid AIO, except for O11 Air Mini.
As for EVO, yes it does have an optional front mesh mount but it defeat the purpose to get it. if that's the case, it's of no difference of getting a Lancool II or Lancool III or even a Lancool 216.
If die die want to have windows infront and at the side. Montech Sky Two will do the trick and it's cheaper.
As for the 4080, is your pocket, so long you are happy with it. I am just saying that spending so much on a GPU for games is not very practical.
