DIY PC Rig Recommendations For 2026
bzkx23
hi need some help here as my 10 year old pc is finally starting to fail on me
and sorry in advance cause i'm pretty noobish on this as well
below are shortlisted items and would wish to keep budget to 3k, wifi not needed for mobo
Price
ProcessorIntel i5-13600K843 ud bundle
929 elite ax bundle
MotherboardGigabyte z790 aorus elite ax ddr5
or
Gigabyte z790 ud ax
(if u can recommend another one i wouldn't mind too)
RAMG.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory240
GPU4070ti - can't decide to go with which brand
SSD 1Samsung 980 PRO M.2 NVMe x 2159 x 2
PSUEVGA Supernova GT 850W 80+ Gold195
CasingPhanteks eclipse p600s208
CPU CoolerAORUS WATERFORCE X 360
really appreciate everyone's help on this!!
NightRaven49
But let's say if i am looking at 6800xt due to the fact that i'm looking for a card with more vram. 650w will not be suffice?
650w should be enough even for a 6800xt. not prone to spiking compared to rtx 3000.
deciding between 4070 Ti and 4080 at $531 difference. Inclined to 4070 Ti paired with 7800X3D at 1440p. Is Diablo 4 CPU or GPU bound? Alternative views welcomed
thats paying more than 40% more for less than 30% more performance, though u do get 33% more vram. from what i see online, d4 looks more gpu bound, at least with a 5800x3d or 12700k. but even at 1440p cranked, i see fps numbers well over 200, so u could probably get away with a lesser gpu if ur monitor cant keep up.
$3525
AMD Ryzen 7800X3D
Zotac RTX 4080 Trinity 16GB
Gigabyte B650M Gaming X AX
32GB ADATA XPG LANCER RGB DDR5 6000MHz CL40
AFTERSHOCK Glacier Mirror 240mm Watercooling
1TB Samsung 980 Pro Gen4 SSD
850W Deepcool 80+ Gold
Tecware VXL Dual Chamber ATX
or
$3104
AMD Ryzen 7800X3D
GIGABYTE RTX 4070TI GAMING OC
ASUS TUF GAMING B650M-PLUS WIFI
ASUS TUF GAMING LC240 Watercooling
SILVERSTONE DA 850W 80+ GOLD
MONTECH AIR 100 BLACK ARGB mATX
Planning a purchase this week, dear gamers, please advice 1440p monitor now, planning for games like Black Myth: Wukong, Diablo 4, WoW, Guild Wars 2, Baldur's Gate 3, Trine 5 and Cities: Skylines 2
i would suggest u look at the 3.1k build i suggested in op, and maybe swap out the 13700 + b660 + xmp ram for a 7800x3d + b650 + expo ram combo if u prefer that. u can also opt for the thermalright peerless assassin 120 for $70 from bizgram, as mentioned by others it will probably perform better than those aios.
Price
929 elite ax bundle
or
Gigabyte z790 ud ax
do provide more info on what u r planning to use it for and ur monitor resolution and refresh rate if gaming.
for gpu, just get the cheapest 4070ti u can find, unless u plan on making a gigabyte themed pc (which looks like it to me :s13: ) in which case just get the cheapest gigabyte card. ssd i would suggest u get the sn850x which can be had for cheaper and doesnt have the firmware issues. psu wise 850w quite overkill, maybe can get a 650w-750w model and can consider other models like the msi a-gf series which is somewhat cheaper and better than the evga gt series (actually for ur listed price can get rog strix psu le). as for cpu cooler if u can find the arctic liquid freezer ii, that would be the best value option around $160 for the 360mm.
bzkx23
HAHAHA not really gigabyte themed but more of just google results recommending these boards
this pc mainly used for severe multi-tasking + gaming (basically any new title releases) on at least 1440p @ 165hz!
but would you recommend the 2 mobos above or any other recommendations??
and i guess i have to use the wattage calculator again 😅😅😅 but future-proofing with 850w is advisable or not??
thanks so much again in advance!! And so sorry for so many queries!!! Been some time since i built a comp
BluEsiGn
Hi,
im a noob reading around on building my 1st comp as my current old comp is dying. I mainly use it for gaming while watching drama/anime at the same time. i hope it can last for nxt 4-5years without any more upgrade and hopefully a stable system(dosent breakdown) as im very bad at hardware. hope it is 4k ready + ddr5 and budget around $2800 or less. im taking the pricelist from dynacore(or any where is cheaper? pls recommend) as i wanna buy and let seller to build for me as i do not know how. Currently im running 2 monitors, LG ultragear 27GN650 for playing + old 60hz monitor for watching video.
im looking at this setup,
ASUS PRIME Z790-P WIFI-CSM D5 + i5-13600KF $780
asus tuf gaming 4070ti ?
KINGSTON FURY BEAST RGB DDR5 6000MHz CL40 16gb x 2 $330
WD Black SN850X Gen4 7300MB/s Nvme M.2 Ssd 1TB $160
Asus Rog Strix 750W 80+ Gold Full Modular Psu $149
for casing and cooling i do not know what to choose?
i like fractal torrent but i think it will exceed my budget. is there any thats like that but below $200 that can fit the above?
air or liquid cooling is fine as long as it cools the cpu.
if i buy everything from dynacore(or another place) will they give discount and do i have to pay extra to ask them to help me to build it? will they help me to overclock or i have to learn myself.
after setting up, is it the windows10/11 unactivated, do i just go to shopee and buy the windows 10/11 activation key for around $20 and i can start using?
sorry if i ask some questions that may seem silly to you gurus as it's my first time trying to get my pc and i have no knowledge. hope to receive guidance.
zidane13
So I have bought a tecware flatline case, which comes with 3 front 120mm fans and one back fan (all 3 pins) . I'm thinking of getting 2 arctic p12 120mm pwm fans for the top of the case. Is it a good idea to change all the fans to pwm fans?
Hyperephania
4pin PWM easier to control the fan speed based on the temperatures. Can just get a bundle of 5 fans of P12 if you got the extra budget.
I think 3pin need to control by voltage and not as accurate. (need experts confirmation)
Siyu
Hello,
I got 3 questions, for a friend in Thailand, baht
1) Any comments on this build?
2) what is roughly the price?
3) Are fans missing?
CPU: AMD Ryzen 7800X3D
M/B: ASUS ROG Strix X670E-E Gaming Wifi
VGA: ASUS GeForce RTX 4090 ROG Strix OC
RAM: G.Skill Trident Z5 RGB DDR5 32GB (16GBx2) 6000 Black
SSD: WD - 1 TB (SSD M.2 PCIe 4.0 WD BLACK SN850X)
PSU: silverstone 1200w
CASE: Thermaltake Ceres 500 TG ARGB Black
LIQUID COOLING: THERMALRIGHT - FROZEN MAGIC EX 360 ARGB AIO Liquid CPU Cooler
Current price is SGD 5827 converted from 150,000 baht
TIA
kaixax555
Hello,
TIA
1. Do you really need the X670E features? Is your friend going Asus only?
Personally I think the MSI X670E Carbon is a more well rounded board if you are aiming for a X670E. Sure the power stages sound more fancy, there are 2 more type A and one more Type C, but the MSI board is more flexible IMO.
MSI PCIe configuration can go to x8/x8/x4, compared x8/x4/x4 on the Asus board. Also most AM5 boards are overkill on power stages, the 110A VRM on the Asus won't perform any differently from the 90A VRM even with a 7950X. This will be even more overkill for the 7800X3D.
If you need the POST code but don't need the chipset, B650E-E Strix is significantly cheaper.
If you need the chipset but don't need the POST code, you can get an Asrock X670E PG Lightning.
If you are looking for a relatively affordable B650E board, get the Asrock B650E PG Riptide. The layout for this board is such that you can add M2 SSDs later on without removing your GPU even with a 4090 installed.
For PSU can look at something like a 1000W PSU or maybe even 850W because your 7800X3D doesn't pull nearly as much power as say, a 7950X or 13900K.
Cooler can consider Arctic Liquid Freezer II 360, it should outperform the Thermalright, however given the 7800X3D isn't nearly a power hungry chip, you can go for a smaller 280 or even 240mm radiator.
Thermalright casings aren't easily found in SG at least so consider alternatives like Lian Li Lancool 3 for example unless you really need that LED panel.
2. AMD Ryzen 7 7800X3D + Asus X670E-E Strix 1524
G-skill Trident Z5 DDR5-6000 CL32 2x16GB 279
WD SN850X 1TB 160
Can't find the Thermalright AIO so Arctic Liquid Freezer II 360mm ARGB 184
Asus ROG Strix RTX4090 3309
Silverstone Hela 1200W Platinum 373
Can't find Thermalright casing so I put a Lian Li Lancool 3 199
Total 6028
3. Thermalright case should have fans, AIO also has fans and is breathable so no need to buy more.
mr_won
Hello, I am new to PC building and is quite interested in one of the recommended builds:
value gaming pc, total: $1064
ryzen 5 5600 + asrock b550m/ac311tradepac
kingston fury beast 2x 8gb 3600mhz cl17 ddr472dynacore
wd blue sn570 500gb57tradepac/dynacore
powercolor rx 6650 xt hellhound405dynacore
cooler master mwe 550w v2 bronze69pc themes
Browsing a few of the websites providing ready-to-ship desktops, it seems like the "Master Mk1 series" from dynacore come close. On the website, there are also some alternatives in the 1100 - 1200 price range that has different motherboards, SSDs, CPU and graphic cards combinations.
A few questions that I have:
  1. Several online posts suggests that in terms of value, R5-5600 is better than R5-5600X. Would it better to save the money to go for 5600 instead of 5600X?
  2. Also, for GPU and 1080p gaming in general, would RX6600 suffice (non XT)?
  3. Recently, there are also concerns about GPU VRAM requirements in general. Will it be better to opt for a 3060 (12GB) that cost about a $100 more for better future proofing? I understand that there are also some benefits like better ray-tracing and is highly dependent on individual use-case. But what are your thoughts in general?
  4. In terms of motherboard, is the downgrade to A520M advisable or should I just stick to B550M, assuming the Tecware Nexus Air M2 case is used.
  5. What about building this in an ITX build? Is it even advisable? (Temps, noise, fans, pricing of smaller case, etc)
  6. In general, following the recommended build, is the fan noise very high / distracting or are they tunable?
Sorry if that is a lot of queries I have but I hope someone knowledgeable might be able to provide some advice or recommendation.
Thanks!:)
NightRaven49
i would simply go for the cheaper of the two if there are no unique features that i want in the more expensive one. from what i remember the z690 ud was already a pretty decent mobo to begin with, so i dont think the z790 model will be worse. but if ur just general use (multitasking is still within this realm), then i would suggest going for a 7600 + a620/b650 as the gaming performance will be similar for a much cheaper price, plus lower power consumption.
if u have the budget sure, though imo most people should be good with 650-750w.
it depends on what u like about the torrent. aesthetics wise there are barely any alternatives (see if u can find the torrent compact?), but if u are more concerned about airflow, then i have suggested a few cases with good airflow in a spoiler towards the end of the op. for 13600k, if ur just gaming, a good air cooler like the pa120 should be fine, but if u also plan to do core heavy tasks then better to invest in a aio like the arctic liquid freezer ii 360. if ur just gaming however, i will suggest u consider the ryzen 7600 combo as i recommended to the bro above.
maybe can bargain the price abit, and usually if u buy everything from them they wont charge build fee, though u can always confirm with them. oc wise i dont think they will do it for u, so yes u will have to learn urself, but then again oc headroom varies from chip to chip so it is really a luck of the draw.
should be inactivated unless u also buy the key from dynacore. but the key from shopee should also work just fine.
Hello,
like kaixax mentioned, everything is quite overkill. mobo and gpu definitely can step down to lower tier models without losing anything in performance. i would also opt for more well known brand name psu, silverstone doesnt have a lot of good models like corsair or seasonic.
the fact that this is almost twice the price of the highest price build i recommended while only offering at most 20% more performance is just :s14: i wouldnt go this route for sure.
yes.
i personally would not do so. 3060 is at most 10% faster and rt performance at this level of performance is basically unplayable without upscaling (not that u want to use it at 1080p anyway), so for me the 6600 is better value. in terms of vram, there is literally only 1 game so far (tlou1) that breaks 8gb cards at rasterised 1080p and that is when cranking graphical settings to ultra. in general ultra preset is quite pointless in boosting visual fidelity over lower presets, so u can get 99% of the visuals with high preset and also avoids the vram issue in that game, making even 1440p playable. in the vast majority of games, vram wont be an issue for 1080p.
from what i see, a520 is not much cheaper than b550, plus the 6600 needs all the pcie bandwidth it needs, so best to stick to b550.
if ur budget allows sure, itx parts tend to command quite a premium over regular m/atx. 5600 + 6600 is not a very high power system, so even with a compact case thermals and noise should be manageable.
should be quite manageable and definitely tuneable.
also dont worry about asking questions, thats why this thread exists :)
kimsix
agree x670e-e is overkill.
x670e-f is more than good enough for a top end am5 splurge.
it has eclk to push x3D cpu for extra 3-5%.
it can do full 16x-4x-4x pcie5.0
it's atx size and Asus very on ball with am5 bios so far :o
Siyu
WD SN850X 1TB 160
Total 6028
WD SN850X 1TB 160
Total 6028
Thanks for the fast reply!
My friend not going for ASUS only, he said that he contacted a shop and they recommend him that.
Infact, i am going to pass him my old GPU Palit GTX 1060 Dual 6GB GDDR5 when he comes over. He told me that he doesn't have enough to get 4090 now. So i say use for now lor, next time got more moolah, upgrade the GPU.
Like you say, maybe you can recommend him to downgrade and a different RIG, he is only 30ish and wants to use it mainly for Trading US market) plus play D4? But no plans to buy a 4k monitor yet. He really likes 7800X3D. And needs it to be quiet and not hot because afterall, he has his computer in the bedroom.
kaixax555
IMO it's ridiculously overkill, you don't need a X670E board like that for the 7800X3D, in fact the cheapest ASRock B650M -HDV can power a 7950X comfortably
Also 4090 is really damn pricey, if you can afford it you can go for it but can also consider the 4070Ti/7900XT or 4080/7900XTX instead.
This is my recommendation based on the 3K (high performance + productivity) setup
AMD Ryzen 7 7800X3D + ASRock B650E PG Riptide 1093 (Dynacore, please ask them beforehand because the last time I actually bought this board from them, they don't want to carry ASRock anymore)
Among the cheaper mobos but with the B650E chipset, solid VRM, WiFi and a sensible PCIe/M.2 drive layout. Even with a 4090, you can add additional M.2 drives without removing the GPU unlike most motherboards
G-Skill Trident Z5 Neo DDR5-6000 CL32 2x16GB 279 (Dynacore)
The timings seem to be Hynix die, should be more likely to work out of the box with the EXPO profile
WD SN850X 2TB 265 (Dynacore)
Generally nice and fast PCIe4 M.2 SSD
Zotac RTX4080 Trinity OC 1792 (Dynacore)
Should still be comfortable at 4K, if you can find the ASUS TUF at about same price range can consider. Also consider the Sapphire RX7900XTX Pulse @1629 if ok with AMD.
MSI A850GF 850W PSU 182 (Bizgram)
Solid PSU, can consider ASUS Strix 850W @187 as another option
Lianli Lancool 216 130 (Dynacore)
Very cool case, can fit a 4090 easily, can also fit a 360mm rad at the top for your water cooling needs
Arctic Liquid Freezer II 360 162 (TechDeals)
Probably one of the best performing 360mm AIO out there, alternatively can consider Thermalright Peerless Assassin @75 for an air cooling option
Total 3903
dgjy91
Hello, anyone has any advice on this set of ram?
Crucial RAM 32GB Kit (2x16GB) DDR5 4800MHz CL40 Desktop Memory CT2K16G48C40U5​
I found a good deal on Amazon to upgrade my ram, but am not sure if this is suitable for my built.
Rough specs:
i5 12600KF
Asus Z790-P Wifi CSM
3090 TI
Thank you!
kaixax555
Rough specs:
i5 12600KF
3090 TI
Thank you!
Is probably the most basic RAM you can get, if you want to carry over in the future though, this RAM basically doesn't clock any higher than 5400MHz at all.
You could go for this RAM instead, better scalability to carry over to future DDR5 builds
https://www.amazon.sg/TEAMGROUP-T-F...8&sprefix=Team+group+DDR5+6000,aps,321&sr=8-4
Based on Asrock QVL this is Hynix M-die so it will clock much higher than the Corsair RAM using Micron die
dgjy91
Thanks! I am on a 12600KF so I believe the ram frequency is pretty much limited to 4800 MHz for now. I don't intend to upgrade until a few years down the road. Given my use case does the crucial one make sense? I can get this set for about $100 now on Amazon.
kaixax555
With newer BIOS revision your combo is more likely to support DDR5-6000, at worst you can use the 5600 XMP profile (there are multiple profiles in RAM kits) and it would more than likely run it, unless your 12600KF has utterly trash memory controller.
The Crucial is cheap yes, but unless you are really on a shoestring budget, the Teamgroup RAM is better value to me.
dgjy91
Thank you! Was also looking at Corsair but seems like Teamgroup is better. Any advice against getting Corsair in a similar profile?
kaixax555
According to Mach in AMD thread, Corsair is like lottery, unless you check motherboard QVL for the exact RAM model, can't guarantee the die is Hynix (might be Samsung which is worse than Hynix).
Kingston is pretty much guaranteed Hynix from 5600MHz and above but is pretty pricey compared to Teamgroup.
