Door bell with camera recommendations
evq
Notification received from doorbell thru my phone eufy app is almost instant if I choose the text only option. Eufy doorbell has 3 type of notifications, another is text and thumbnail and last is text 1st followed by thumbnail. So far I only tested the text notifications at home. Not so sure the real scenario where I am elsewhere and someone ring the bell. Live feed video is lagging of 1 to 2 sec.
thanks, btw, where does the vid footage saves?
winningeleven
Eufy doorbell comes with a self storage of 4GB. It will overwrite once the full storage used up. 1 short video is about 30++ seconds. It take up 1 to 2 % of the storage size.
applegal88
Anyone know if the Ring video 3+ if we buy from US and ship to SG, can it be use? And do we need electrician to install? Price is a lot better to buy from US compared to SG.
wahjohreno
I simply bought a transformer that is specified to work with it (mine is Ring Pro). Don’t even need electrician.
My setup is electrical socket > 240 to 110v > transformer > Ring
gooifier
Hi, anyone use the Ring Peephole Cam?
Can show a photo captured by it? Also, I feel like ordering direct from Ring since it’s CyberMonday and it’s cheaper.
Any issues using a US set?
shawniiex
Hey guys, what do you guys use to cover the hole of your doorbell after replacing with the nest?
winningeleven
Don't make the same mistake as me.
Maybe I have to get a pro who know exactly in what need to be done to the old existing doorbell hole and install a doorbell bracket
I tried to DIY with fill and fix foam and after that applied the wall punty. It is my 1st time doing and turn out very ugly. Then big mistake is when I start to drill in the screw bracket for the doorbell. I just realised the filling foam and the putty unable to hold it. In the end, removed the filling foam and putty, covered the old hdb doorbell with the standard blank cover. Make another small little hole to pull the wire from the side. Drill the door bell screw bracket beside it on the concrete wall.
Syaman
Just wanted to update that I bought the Eufy 2K video doorbell (battery operated) from Amazon UK. Managed to get it when it was listed on the Amazon Renewed store, so the price was considerably cheaper than usual retail. Battery life is now at 95% after 18 days of use (motion detection not enabled as my flat faces a neighbour's). This is a much better experience than my previous Ring 2 which needed a swap of batteries every 7-9 days even with motion detection turned off.
shawniiex
Haha bro. Nice DIY attempts la. It's all about the fun isn't it?
Yeah I went DIY shop wanting to buy a larger acrylic panel to cover then ownself drill. But they only sell the 10by10 blank cover. Gonna drill later.
shawniiex
Anyone looking for a Nest Hello?
Bought extra for my aging dad but he say don't want in the end.
PongRareRare
I’m thinking of getting one too. Do you need drilling on your door?
How does it work if no motion sensor? Camera activated only when someone press bell?
Besaid
For the bros here that plan to use US based 8v doorbells, I was playing with Netatmo's configurator and thought of using the 'approved doorbells' so that we can ask our electrician to install.
What do you guys think of this? it comes with an Integrated 8 V transformer.
Byron 776 Wired Doorbell, Integrated 8 V Transformer
Now is how to get it to SG within reasonable costs. Currently Amazon shipping itself is more expensive than the bell XD
jockster
I’ve shortlisted the Eufy doorbell too. Just curious, why did you decide to buy from Amazon when eufy is sold locally? Is it just the price?
singlite
You need to buy the global version. The china version is geolock just like some of the Xiao Mi doorbell.
uNrEaLiTy
I got my eufy wired from lazada at $299 (local seller) and also got the power adapter from the same seller for $20++. If u Google search power adapter for doorbell for nest, ring, eufy etc. U can get the same for $11 from those China seller.
Yes. U need the step-down to make it work. The requirement voltage for the door bell is much lower
Hi bro, can take a photo of the adapter you using? bought a eufy 2k pro from usa, and having a hard time to find the correct adapter
winningeleven
evq
i just ordered the Eufy 2K Wireless Video Doorbell with the base station. Hope it is good
