Door bell with camera recommendations
Devilsire
Used TAPO for 1 year already. Damn good. Movement also alert you. Press doorbell can talk to person. Can record preset messages
Ard there. The battery one day 1 percent reduce. So every 3 mths maybe need to charge for few hours. But easy to install and easy to take out and charge
What I like also is that it is quick enough to capture motion for ppl who is walking pass corridor.
Previously i shared before, its definitely the best wireless doorbell cam winning xiaomi, tuya & random china brands handsdown.
Features rich with lighting, detection zones etc to filter out "false" motion
Sensitivity is quick & good (within split second from detection to recording)
Very good battery life, can also buy their bty as spare replaceable bty
Integration with google home, can set notifications on google home linked speakers/display & chromecast etc
The only con, sometimes it takes several secs loading to connect to livecam via app in order to comms with courier etc (might be due to network)
And also Rich Notifications requires subscription
Best price now, 96 - 6 shop - 7 platform = $83
Probably the best wireless doorbell <$100 from my experience
Billyboo
Is it better than google doorbell too? What are rich notifications?
Devilsire
cant comment on google doorbell as i dont owns it, mainly cos i feel its overpriced :ROFLMAO:
rich notification is sending you notification with picture vs text
stillgottheblues
Can the door chime on Tapo door cam be turned off, with only motion capture? I dislike people pressing my doorbell.
Devilsire
Can the door chime be turned off at night?
there's 2 part, the doorbell and the hub/chime.
Doorbell can set on/off, volume, led light, flash light, scheduled app notifications
Hub/chime can set on/off/scheduled, volume, tone
i rather ppl pressing doorbell than knocking/banging on door :o
stillgottheblues
Where do you guys place the doorbell camera? On the door or the wall beside the door?
Am trying to make a decision. Seems quite hard due to my mischievous neighbours. Not sure if they'll remove my doorbell in the middle of the night 😁
LIN_JOEL
Hi, may I know will I be able switch and connect the Tapo 230S1 via mobile data (Portable WiFi) after successfully setting it up via ethernet cable?
cos I’m intend to setup one for my new house and only subscribe internet when I ready to move in.
wacko
shouldn't be a problem, WiFi is WiFi.
daniel_83
didnt install a TAPO or google doorbell because cant see what is in front of my doorstep
And my lift/walkway/corridor is not in front of the door, so the doorbell camera needs to be tilt in an awkward manner to be useful
so i installed a battery camera instead
very small and light, just double-side tape to the top of my gate
vstarcam_1080p_battery_mini_wi_1634462918_f56310c5_progressive
But battery life is short (~3 weeks) and unable to communicate with visitors
i use a powerbank to charge it (leave it plugged in)
my main purpose is to be alerted when someone is at my door/left a parcel at my door
HelIoo
Nice. Any link to this product? What mobile app does it requires?
winningeleven
On the wall beside the door which is the original doorbell location.
My doorbell is damaged when I was in overseas , came back and saw it as if someone gave a hard punch on it.
My unit is the only one which install a doorbell cam.
LIN_JOEL
For my case it failed.
Not sure whether is my outdated device issue or Wifi over Mifi not supported.
I'm tested using Singtel 4G with the old Huawei E5372 portable router.
Signal very weak to 0.
However I got the Tapo at a good price during Lazada Feb sales....D230S1 with additional A100 battery @$90.
hkchew03
99% router issues, doesn't even have external antenna. Your signal will just be overpowered by neighbours wifi. 2.4ghz is extremely crowded for most places.
RyanJ
Ur doorbell cam managed to capture the person that did that ?
