e-Remote Broadlink RM-Pro
Elon Jobs
has anyone tried installing a similar smart switch across those water heater - i got 3 tank heaters at home ? I saw this eTouch 20amp single gang switch, anyone tried that before ?
I'm using eTouch switches myself, but I don't have water heater at home- I'm using those gas water heater. If you have questions on Broadlink and eTouch products, you can contact this lady on Carousell called Desiree. She's the official distributor and she would be able to answer your questions. She was very helpful in me setting up my own DIY Home Automation.
infernolord
Hi For those who using TC2 and Alexa,
Do you have any issues lately after updating both apps? My TC2 switch fail to response after updates...
Any one please help?
evelynsiow
Livolo switch from aliexpress... quality looks good...
Too bad i bought wrongly... this requires neutral... duno carousell will have ppl wanna buy or not...[/QUOTE]
Hi Is this Livolo a RF wall socket which I can control on/off via Broadlink RM?
mUdpOolEr
anyone using the RM Pro+ with Daikin Smiles series? Heard that there are some issues.
Elon Jobs
Elon Jobs
You can use Safevue 5 in 1 Smart plug outlets. Since you have RM Pro. Cheaper alternative than the SP2
I just Googled it, looks like a good deal! But one time must buy five right? I don't need so many.
ralfale
Those on livolo smart switches, how is their failure rate? Anyone using more than a year no issues ?
Also, you got it from carousell, aliexpress or taobao?
leongws
I'm using since feb last year. Consist a mixture of 1, 2 & 3 gang one way switches. Total installed 7 of it with some as spare. Mine bought from livolo official store from TaoBao and it is without Neutral.
So far all still works fine except for 1 of the 1 gang switch where the blue backlit light during off mode has gone off. Once switch on, the red backlit light still works. No concern to me.
Aditshar
You can make use of the remote, physical switch button and smart integration (via broadlink rm pro)
I make use of it for standing fans, iron, standing lamps, LED lights etc. You can make any manual on/off switch to a smart ones with it. For the price of 2 SP switch, you can get 5 of smartvue plugs.
