e-Remote Broadlink RM-Pro
Saline
Hi, anyone using Livolo switches?
I bought the switches and the RF remote. it's paired up nicely. but i'm not sure how to I link it with broadlink rm pro.
Errz
just got the rm pro + today. how do I add fan remote with + / - fan speed? the fan template only has one wind speed button. Am using Haiku fan
singcheng
Same problem here... Pro+ could learn one speed's IR but not the other speed...
jemcerato
Thanks. Guess i will hav to get e gateway.
Also i tried to use pro+ to learn n control my 305mhz fan controller but failed with IHC. Any advise?
Not possible unless the RM Pro can be hacked like Sonoff rf bridge to run custom firmware. RM Pro was never positioned as a receiver though I suspect technically it can be since it can learn rf codes. If you only need a simple activation by the door sensor to switch on lamp, it may work by getting a cheap RF door sensor and pair it with your RF switch. But without a controller, you can't reset the state and do advance if-else controls.
Elon Jobs
That’s weird. Did you use user define template? And which app- IHC or e-Control?
My RM Pro was able to learn multiple IR frequencies from my KDK fan.
medscy
which app u using? I can using a Haiku fan and managed to find the Haiku template in eControl with speed up and down
medscy
Do you know the encoding used by your fan? if it is using fixed code like 2262, it should work...
Errz
How do I integrate eControl with google home? I can only see Broadlink Smart home, which is tied to the iHC?
medscy
EControl cannot be used with GH. Actually you are not missing anything. The GH cannot integrate fan templates at the moment. even if it does like in Alexa, it only allows turning on and off. I tested the user template in iHC... I think it does allow you to increase the speed of the fan... Just that the template creater labelled it as "wind class" for whatever reasons... I think you can amend that.
Icaruz
I am currently using the Broadlink E touch 20A Switch for my water heater. I can't seem to add it in ihc, only in e-control app. How can I add it into ihc?
I tried searching the user library but none of the frequencies work. Is it possible to manually add the frequency from the one I have in e-control app?
medscy
Nope... It is not possible to port the frequency from eControl to iHC. The only way is for you to get a physical RF remote to pair with your eTouch switch and then get iHC to learn from it.
Icaruz
The only method is for physical controller to learn? Because I tried holding the switch for the rf light to blink to learn the frequency but it is not capturing it.
Any kind soul with this switch to upload it to user library?(The current one i found on user library doesn't work)
Will it work if I use another broadlink rm pro+(from my friend) to fire the signal via e-control and learn the signal on my broadlink rm pro+ in ihc?
