e-Remote Broadlink RM-Pro
Specialfeelings
The TC2-3 gang will meet your needs. But do ensure that the total load of your lighting should be less than 100W per gang. The usual lightings should not have a problem with this.
It does not require N line. Whether it is hard or not, it is subjective... 😂. I guess most of the forumers here think it is fairly easy. Safety comes first.. Make sure you turn off your circuit breaker before proceeding. If in doubt, just engage a qualified electrician.
Ok thanks for clearing my doubts ^_^.
rza29
Anyone have tried using ebroadlink and change from Alexa to Google Home before? I won a Google Home which has better sound than my echo dot. So thinking of swapping it out
singcheng
Why need to swap? You can have both Alexa and GH working for you...
Posted from PCWX using phone.
Creator of OEM Comparison Chart & Plan Calculator.
Ohm user since April 2018.
Elon Jobs
I need addition capacitor to solve the flicker issue . anywant can share where to get the extra or picture of the capacitor ( with value ) so that I can find ??
Sorry I can’t help, my capacitor was given to me by the seller. I don’t think she sells capacitor. You can PM her and ask on Carousell. Desiree.
h_ohtan
IHC on and off switch disappeared
Hi, anyone encounter issue with IHC pairing TC2 in IOS? After paring, the control of the On and off switch keep disappearing and the pairing keep show up when want to use the control in the IHC app.
jemcerato
Hi
Installed today and all is working. 1 switch to 2 lights. Only installed the capacitor in 1 of the light and the problem of on/off is resolved for both. Below is the installation and info of the capacitor
https://imgur.com/OCGGH1d
https://imgur.com/NFwIPj4
Hope it helps
dankoo
Need some advice:
I recently bought another Blackbean to control aircon in my other room. However, it seems that the timer function does not work properly. While testing it, it works and can turn off my aircon, however, when I set it to 2.30am, it does not work...any idea why?
KennyKhor
Hi
Hope it helps
Wow.. Do you know where can i get it ??
medscy
Need some advice:
Obvious as it may be, do you have the habit of switching off your wifi/broadband at night before going to bed?
Elon Jobs
Broadlink Experience Centre opening on 11th. Will head down soon to check things out and update here if I find anything interesting.
Any interesting ???[/QUOTE]
I finally had the time to head down in person to take a look this afternoon. Really nice place, well furnished, just like an Apple Store, just that the products don’t cost an arm and a leg. All the Broadlink home automation products plus GHM and AED etc are all on display. There are some other brands too like Funry etc.
The new and interesting stuff are the Broadlink Smart Curtains and a smart rubbish bin! Really got to see it to believe it. Most importantly, the staff there were super knowledgeable and never anyhow upsell me.
Anyway, I know it’s not the most accessible, but there’s free parking and shuttle bus for those who don’t drive, plus if it’s at a mall or what overheads will be high and the costs will be inevitably passed down to us.
186, Woodlands Industrial Park E5, #04-01F, 757515
https://goo.gl/maps/i9ZifeRKBFaVTtqn6
Personally, I feel it’s a great place to get a feel of the products and visualise how your future smart home is going to be. It’s like test driving a car before you buy it. More importantly, I think it would be the perfect place to convince your wives who will definitely have doubts and suspicion about the usefulness of smart home automation! 😊
I will upload some better looking photos later, my old iPhone SE camera really doesn’t do the place justice.
cscs3
Hi
Hope it helps
Is a 0.1uF 275v (250v is good enough). Make sure is x2 type. This capacitor basically bypass your electronics (active componment) so that you get some power to the swtch to work.
You can get these capacitor from Sim Lim tower (not Sim Lim Square).
Elon Jobs
cscs3
In fact, some of the items need to consider when you setup these so call smart devices: (many has discussed in YouTube too).
1. Availability of WiFi and how to make it failed safe. Eg. Turning on some important devices like aircond and cooker and subsequently internet access is down for some reason.
2. Something screw up, and yet the setup are unable to bypass/fallback to manual by other family members.
3. Network change eg provider change, router change etc.
dankoo
haha...no...wifi is 24x7
I actually have 2...the one in my master room is working while the other room just dont turn off the aircon.
shawniiex
What 3 pin smart plug you all using for things like TV and Fan?
See Amazon USA so many cheap ones. Damn Sian 3pin ones all so expensive.
sellun
Lazada got cheapo ones from China also.
I'm using sonoff s26
Sent from HUAWEI BLA-L29 using GAGT
