Can anyone share the wring for 2way switch using TC2.Almost finished replacing all my switches, only left with the few with 2way connections. Thanks!
Hi, Shachoi master.. haha
Just gotten my RM set. i am abit frustrated. Alexa only works with RM pro? Does it work with my RM mini 3 bean? My alexa could not detect any of my smart plug or the bean.
Is it a issues of configuration, do i need to get RM plugin on an android to get them work?
first of all, wat is the broadlink app u r using ? e-Remote or IHC ?
for e-Remote, yes, u need plugin on another android to act as bridge.
for IHC, no, no need plugin BUT your controller template can only be config as 'tv template'.
u mentioned smart plug oso not responding ?? did u enable the respective skills in Alexa first ??
and finally, u the first person to hav the RM mini3 dat i noe! ha
1.Oh there are two separate app??.. apparently, e-remote can detect my UK SP2 smart plug but not IHC
So which do you recommend to use? If i use IHC, how my android work?
The andriod app can't find my bean as well.. -.-
2. For IHC, is it true that Alexa detect all RM devices as TV? meaning all must config like TV in IHC?
damn chim.
I have bought the RM Pro, 4 x Mini, smart plug, air sensor, door/motion sensor. The ihc app can detect the mini and smart plug. But not the Tc2 switches. Did not have the time to setup everything yet. Trying to setup with Google home with a bridge, but no time to look into that. Need to solve the 2way switch issue too.
Wah. U r the real broadlink fan!![]()
Hi everyone,
I just gotten the RM-PRO+. I'm able to setup using the IHC app on my iphone, to control my bedroom fan and aircon.
But i still not able to remotely on/off these devices while using mobile data before i reach home.
Is it not meant to be or need some tweaking?
Need some advices..
Thanks.
Hmmm.. No need tweak for remote usage leh. Jus click the app as per normal shld work with mobile data network.
Havent try ihc but e-remote works
I have both apps, and tried both using mobile data only, both works.![]()
I keep receiving the error message " Sending IR Code Failed " while i'm on mobile data. Weird...
Hmmm.m..
not sure bout that as i dun encounter that, im using the latest e-remote and IHc app on google Playstore.
my hp Android version is 7.1.1
