(GPGT)Espresso machine hoot
jkohlc2
whenever you guys buy new beans, how do you get the recipe /brew ratio for the beans ?
do you guys usually trial and error ?
just feel bit of wastage this way as usually first few cups would be thrown away.
waste 就 waste, 没有办法的
usually just dose 18g because my portafilter basket is 18g
just try to hit 36g yield in 30s then adjust from there
too sour? grind finer a bit
too bitter? grind coarser a bit
taste ok? don't change anything
mamboeidos
dunno y sometimes i grind fine till extract takes 2 mins for 36g while trying to dial in also sour leh....
hardwaregone
If your extraction can't finish in 30 seconds, that already sounds like a problem.
2 minutes, must be over extracted till the notes are razor sharp and super unpleasant.
Lighter roast are sour, just go for those italian darker roasts.
A darker roast that retains some acidic and fruitiness is well done in my opinion. :o
wira
any recommendation for cheap and good coffee beans for beginner since going to be doing lots of trial and error and no point getting expensive beans
potato13
jkohlc2
120 seconds for 36g like too excessive already
can try grinding coarser and see how the taste is like
jkohlc2
tiagong redman/phoon huat beans are quite decent
mamboeidos
why i got 2min was becos i am using J-max hand grinder and for espresso they say 120 clicks.....
I tried 125 clicks tool 55 sec....maybe need to go to 130 clicks instead of 120 clicks
hardwaregone
Their website say italy roasted wor, I read it as roasted in italy, not Italian roast.
Like that fresh meh?
I've been buying different beans in the office and the staff especially the expats still prefer this.
I never had a problem. Crema is nice for the dark roast, no oily beans. Those flowery fruity or honey notes which normally deteriorate the soonest from oxidation are all there.
So what should I be concerned about?
I had more problems with some of the local roasters over consistency. :o
wira
usually whats the roast date when you purchase it ? like how long since the roast date will it be delivered to you ?
hardwaregone
It only has a best before date.
I no longer chase roast dates with them and I don't think it matters.
Last CNY I found a more than 1 yr old 1kg bag that some fellow chucked behind some Maggi mee in the pantry. Can't find any key difference besides a new batch. :o
My days of chasing all those intelligentsia, Fika Fika, and whatever coffee are over. :o
I think the best nordic roast I had was Fika Fika from Taiwan, but being S$50+ for a 450g pack and most casual drinkers tell me it's just so so, so why waste money and time. :(
zyklon86
"Expats still prefer this"
Lol. My expats colleagues love Jura and nespresso.
I can tell difference in fresh, 1wk, 1mth beans. Most people can just by looking at the pull.
I find the established local roasters quite consistent. Either consistently good or consistently bad. Some of the online ones...I don't even know if they are mislabeling their beans.
calbay
Established brands like Fourty Hands are closing down though.
You can't really tell how good is a shot by looking at the shot.
Back then when I was working with this cafe in the states, working alongside with WBC, we used fresh roast solely for photoshoot. We would wait till it degas a certain number of days else it could get really flat. We always stir the espresso and taste the shot before judging from there.
The problem is it's almost impossible to judge how much beans have degas till the point for our usage. Sometimes it could go off really quickly in the summers. Especially the ones with lighter roasts which have very crema to begin with. Consistency is never easy to control.
Later on, we realised that the average joes don't care anyway.
jkohlc2
no hard and fast rule
every grinder is different
every bean is different
adjust until you reach 30 seconds, or your desired taste
jkohlc2
wow you're back
