(GPGT)Espresso machine hoot
kimsix
anyone know where to taste wide variety of coffee notes? :o
i find dump into steamed milk, mostly all shots taste great.. even those astringent light roast also become nutty with milk :o
see many videos like got a lot of variety
but i find 2 type light roast taste more the same floral, tingly and drying
while 2 medium dark roast also similarly, both smokey heavy and tingly oily
jkohlc2
you can try pinhole coffee bar, they rotate their beans quite frequently
or you can try beans from flip coffee roaster, they rotate their beans frequently too
fyi pinhole coffee bar source their bean from flip as well
kimsix
ya just wondering really got so many different notes? or moi bbfa tongue not sensitive to pick up the subtle difference..
instead of buyed expensive coffee outside, better to upgrade grinder? like df64p or niche :o
jkohlc2
gotch some really can taste a bit fruitiness, almost like very faint strawberry milk or melon milk taste when added with milk
i think when first started out we can only tell it's either sour, bitter, or both, after a while will learn how to pick up the subtle taste
same as single malt whisky, starting it just burns and bitter
probably better to upgrade grinder than espresso machine, can squeeze every last bit of taste from your beans
hardwaregone
Not everyone can taste all the fine notes, everyone's sensitivity in the taste bud is different.
You would probably be having better luck finding a wider bouquet of flavours from a blend, from a medium roast pure arabica. But these coffee are IMO, very volatile and are much harder to extract.
Whenever i go Alchemist and order a cup, I always see them pouring away their espressos and they can't even get their extraction constant even though the settings and the beans they use are constantly the same. I would pay attention to their flow rate and how long they extract.
Also whether you or your family really like these profiles is a question because they could really get more acidic and weak, different from the usual coffee people had in their whole life. :(
mamboeidos
Till now i am wondering if i should get a df64p or niche when i have a j-max hand grinder.....
jkohlc2
gotch new DF83 grinder, i know bigger burrs = faster grinding, but i'm not sure about the effect on taste
IcYFl4mEz
One noob question.
Is those nespresso , dolce gutso etc machine , make coffee from capsule all bitter/not sweet one?
even if you add in starbucks mocha capsule etc?
only way is to manually add in creamer/sugar etc?
mamboeidos
One noob question.
coffee itself is not sweet unless 3 in 1
or sugar is added to it
kimsix
for espresso, definitely need a machine, very siong to hand grind. :o
One noob question.
always found capsule kopi got that burnt taste, add milk also no help :o
kimsix
is max out df64p around same price but better?
gbp drop 10% since start of 2022 but niche delivery up to gbp65, while this thread got report of gbp40-50....hoot now or continue price inflation..? :o
seems highlander coffee is somewhat our local distro for NZ?
hardwaregone
The DF83 video don't show the part they press the pump.
I wonder if it will blow the coffee all over the place. :(
jkohlc2
maxed out as in DF64 with SSP burrs?
DF64 can zhng the burrs, now got a few different kind of SSP burrs, High Uniformity, Lab Sweet, etc.
but Niche Zero ish sibei chio
kimsix
but have to calibrate flat burrs regularly, scared contaminate food item
NZ clean also very easy for those with OCD i see. :o
but i found on reddit that NZ is stinky, they act blur sell it higher outside UK.
499 in UK is included 20% VAT
by right export out of UK should less the 20% (499 / 1.2), now we pay UK VAT and SG GST. And NZ dont even need to report VAT. :o
mamboeidos
the VAT issue many has been talking about it.
What they came to was that the item was passed to another party to do the delivery therefore it has "change hands" in UK therefore VAT cannot be claim
