Yup. I bought 3 x 1kg. Now left with ard 1.3kg.. hopefully stock will be back soonMy Arcaffe Roma 1kg is out of stock again. Bought a few bags of 250g hope can last till the next shipment.
Read got new blends coming next month.![]()
how many grams do you drink per dayYup. I bought 3 x 1kg. Now left with ard 1.3kg.. hopefully stock will be back soon
The Breville Barista Touch is a good semi automatic machine for beginners i think.Drinking mainly flat white/ latte, which Breville machine will suit me with a budget of 1500? Looking at beginner/semi-automatic machines and am very open to other makes too.
thanks in advance!
New releases - DF83 and Niche Duo
Single doser or hopper is down to preference, dun think one is " wrong " over the other, just your workflow. If you are the type that today you want coffee A, later lunch coffee B, tmr coffee C then single doser. I am happy with my hopper grinder.
You're a latte/flat white drinker, so good steam power is a must-have. Bambino does not fit the bill. Between the two options, Barista Pro is betterI'm a Latte/Flat white person looking to get my first espresso machine. I have done some research and have narrowed down to 2 options:
1 - Breville Barista Pro
2 - Breville Bambino + Baratza Encore ESP
Option 2 is cheaper and allows me to upgrade the grinder if I want but I really like the all-in-one format of the Barista Pro and how it looks.. What do you guys think?
