tarui04
if im not wrong thats not dust. its because ur paint is slightly thicker.. thats why it dries before reaching the part, thus fomring the cotton thingy.. pardon me if im wrong. u can just add abit more thinner to the paint and try again.
u mean those spider webs like stuffs?
those I am referring to is already on the parts that I left overnight
tarui04
btw maybe I am quite wols but those "fangs" weapons found in gundam00's gundam trinity and arche are related to
tiny funnel like things on quebely and ks-something??
aucheukyan
yup Fangs are homage to the original 'bits' first appeared in MSG as a weapon of the MA Elmeth, so is Funnels, Reflector Bits, Tri-blades, Fin Funnels, Bit MS, Planet Defensors, Bugs, DRAGOONS, Funnel missiles, Rose Bits, Shield Bits, Rifle Bits, Sword bits
There is still another type, wire guided bits, which is another whole different topic.........
tarui04
ah yes rifle bits, etc
i didn't know because gundam00 is the only series I managed to watch frm start to end
tanyieern
Help!
Hi, i need some help on panel lining
This is my first time panel lining. I tried looking for gundam markers, but couldn't find them, so i bought a Copic Markliner 0.05 after getting some recommendations from Gunpla TV. It works, but to my horror, its not permanent.
7267339700
I next tried a fine permanent marker, but the lines looked huge. And they are a pain to erase after making mistakes.
7267342292
What is the standard size(0.05mm, Fine, etc) for panel lining? How to erase permanent marker?
Thanks in advance.
P.s. I also need some advice on removing gate from parts. Using a exacto knife, I scraped off the gateways, but i often get warped plastic (the part turns white). any way that i can prevent that or fix that issue? I have tried sanding it, but its not very efficient. Scraping off with the knife tends to lose alot of detail and only fix the problem partially.
osirisx
7267339700
7267342292
Thanks in advance.
rapahel gundam:s12:
try the gundam marker gm01/02/20
or enamel wash
wrapped plastic is due to u cutting too close to the part, suggest u dun position the side cutter too close.
trim off the excess using the knife, and sand it down to level the surface
tanyieern
rapahel gundam:s12:
or enamel wash
yea, Rapheal gundam. My first HG. building a Enact Custom now for experimentation.
where to find gundam markers?How much do they cost? Any alternatives? Enamel wash looks difficult...
My procedures are:
1. use a side cutter to remove parts from runners. Leave approx 5mm away.
2. using a exacto knife, cut off the nubs( this is the part where i always screw up, warped plastic almost always appear)
3. shave off some plastic to reduce the white colour if the parts are warped. ( i tend to overdo this part in desperation. Alot of details are frequently lost when i do this part...)
4. use a 800grit sandpaper to sand the area smooth.
5. assemble the parts.
Any mistakes i made? Suggestions to improve?
Thanks in advance:D
osirisx
My procedures are:
Thanks in advance:D
gundam markers can be found in hobby shops like hag
the stress marks is usually caused by side cutters cutting too close.....never come across it being caused by art knife
just dun trim it too close, u can still trim off the excess using your art knife....slowly
for me I use grit 400>600>1000
of coz if u can paint it, then the stress marks wouldn't be an issue:D
tanyieern
Hag is? Where are there outlets? Im also looking for tamiya spray paint. I heard from somewhere that kiddy palace sells it, but the one at compass point told me they used to, not now.
for sandpaper, u use all 3 type? :eek: overkill much?
... now then tell me... i was going to paint my enact orange...dammit. Took me 4 freaking hours to extract and sand 1 runner!Thanks for your help:D
osirisx
hobby art gallery, there's 2 outlets the other being hobby art@work. google it they have a facebook page
tamiya spray paint/cans can be found at hobby point/m workshop....the former have a few outlets
sandpaper 3 types, just a habit from my snapfit days....also have higher grits up to 2k but saving it for glossy paints
tanyieern
Whoa, HAG is awesome. 30% all bandai kits for GSS. :s12::s12::s12:(cash and carry, no nets or credit card)
But its at sunshine plaza... where m workshop is... and i live half way across the country.
Though, where is lion building? i google maped it and i got a hobby shop in the US...:s11:
Definitely going to vist HAG. the gundams on display is AMAZING. And literally everything i need is there. Thanks alot for your info:D
mahoken
https://maps.google.com.sg/maps?ie=...oKrrAeH8sGzCQ&oi=local_result&ved=0CAcQ_BIwCQ
tarui04
anywhere can i get "made in china" decals?
as in decals that say "made in china" ? i want to stick on the gundam :s13:
