Huawei Mate 10
Ruriel
Hi,anyone using or has a good recommendation for a clear case for Mate 10 Pro? I tried the Ringke Fusion but it has the rainbow effect at the back.
Thanx heaps!
Ringke fusion provides an additional back film protector to prevent this rainbow effect. I put it on and it worked. I didn't have the rainbow effect. Did yours come with it?
leon0079
Currently using this Mofi case with my brown m10p installed with nillkin tempered glass which feels darn good.
The Mofi case is similar to pixel fabric case with the feel
Sent from S8 using GAGT
KeYoKe
https://i.imgur.com/PXXYScnl.jpg[IMG]
[IMG]https://i.imgur.com/TpN6VQwl.jpg[IMG]
Sent from S8 using GAGT[/QUOTE]
Sic where you get the case?
Skyy
Your nillkin tempered glass don't have the white borders at the side hor?
How's the oleophobic coating?
where u buy from and how much?:D
CS0287
Anyone has same issue that Bluetooth earpiece control does not work sometime ?
My jaybird sometimes connected, but the pause and play button doesn't work... Sometimes it works..
KeYoKe
depending on the curve of the phone. my wife set has halo effect at the side on her m10p pink
using the nillkin tempered glass too
leon0079
yeah this is good stuff man but you have to apply accurately. My friend had the same one but he did not apply nicely so had a bit of white borders. The oleo coating is pretty good if u ask me
bought from shopee nillkin H+ pro 0.2mm at $8++
previously using another brand with gaps at the side after applying and tons of smudges
leon0079
i used to have this issue when i was using my previous sony wf-1000x and i tried on different firmware and the issue remained
after changing to my jabra elite sports now i don't face this issue anymore.
till now, i'm still not sure is it the hardware or was it just software?
Lycanista
Any rainbowing effect and typing issues? Really hating the Imak tempered SP I'm using right now and might want to change into that.
Sent from HUAWEI BLA-L29 using GAGT
snipfer
Anyone knows where is the cheapest place to get mate 10?
Some said go airport and buy cos no GST.
Sent from Xiaomi MI MAX 2 using GAGT
pawn_king
$745+ (normal mate 10 non pro)
-25 scbest? code
-3% CC rebate (depends on CC)
-$10+ shopback
-5% liveup
beats all other mid range flagship! (Oppo/xiaomi/OP5T)
Skyy
Thanks! I ordered the same one from Shopee. I'm ok with a bit of white borders, there are guides on youtube on how to fill them up with oil if it's really too irritating.
leon0079
No issue so far. I would say go for it. The original film protector was good but it's not resistant to scratches
Sent from HUAWEI Mate 10 Pro using GAGT
DaRRenLieW
Can I check anyone using the mate 10 pro do you see slight glue from the front gap between the front panel and the side . Especially obvious near the power or volume button ? Look like little glitter white dots :/
zelot80
hmm.. updated to 132
dont really see much diff but do notice my volume not as loud as b4..
the limiting of the volume option is already turned off too..
knave
Anyone used Huawei beam and or Huawei share between 2 Mate 10s?
Tried sharing files with mine and my wife's (both on v131) and it never work.
