Huawei Mate 10
Ruriel
What's ota ah. Over the air?
Have 2 things with the tools folder
1. Sim toolkit keeps indicating please insert sim card
2. Download folder can't launch
Can the firmware be downloaded from website. Or how can the tools be reinstalled
Which telco are u on. Same patch across telco operators?
Ya OTA means over the air.
My telco is Circles (who's using M1 infra).
eyz
maybe you guys can try downloading the same firmware from firmwarefinder to install again.
silverstone
hello peeps, how is the mate 10 pro for u guys, am thinking of upgrading to it from my xperia z3.
etoilebiscuit
No problems for me so far. Just gotta manually manage some apps. Android Oreo is a pain in optimising apps.
Sent from HUAWEI BLA-L29 using GAGT
Wander
Backuptrans
IOS to andriod need to pay.
Andriod to IOS also need to pay. Just buy the suite
But it's seems like andriod to IOS may be free, using Google drive
Whatever
Apple is not friendly.
They removed the headphone jack bc it doesn't pay them money. All manufacturers of lightning port need to pay them. So the bullsh%t of promoting wireless is plain bullsh%t
Ya.. Having a headache for this. Seems like no other better way, other that paying.
linusz
Which sim toolkit you launch? There are 2 sim toolkit and one of them is for 2nd sim.
Can show screenshot? Only see 1 toolkit in the folder. Where to find second one.
I have m1xplorer which I think is from my m1 sim card as I on m1
watzup_ken
Downloads app working on 132.
Regarding the battery life, 119 was really the best. 7-8hrs sot and longer.
On 132 now with only 5-6 hrs tops.
I don't know if the security patch may have something to do with it. With the recent Meltdown and Spectre problems, the software fixes may likely result in the SOC working harder. Just my speculation.
linusz
Then I better stick to my 119 hahhaha
Sent from Xiaomi MI MAX 2 using GAGT
I reinstall 131. It shows expected 27 hours from full charge. After I upgraded from 129 it showed half the time. Don't know if it's corrupted install or conflicting software setting.
Did a fresh install. It worked
swanpeach
Guys I see in the mate 10 got.. Steps. Running. Sleep. How to track the sleep.? Do I need to buy a device and sync it then it will work,?
CS0287
This is in my app drawer, 2 sim toolkit
linusz
Anytime tried full restore?
Does it restore all app and settings in the right orientation grouping if backed up.
Wanted to try reset to check the download app then restore all
gohbsing
Mate 10 on firmware 131. From 100% to 42% 5hours on screen time with 5hours GPS navigation. Not sure consider good or not.
Skyy
people say ver 131 is lousier than last versions, I also can't tell cos I started off with ver 131 already
