Huawei Mate 10
TheOutsider
Hmm so the update for mate 10 to take photos with AI is out already?
Now Mate 10 is also AI what.
The difference is the new camera interface in EMUI 8.1 that was released with P20. Now mate 10 still running on EMUI 8.0 hence the old interface.
The new interface let you disable AI. Not adding AI feature.
rarenick
Sorry I'm a noob. Mate 10 pro can use microsd card?
Posted from PCWX using BLA-L29
symbiote28
anyone gotten this issue before? when i put my SD card in my computer, it can read and write without any issues. already second time happening.
Paul Lee
I just got my Mate 10.
I know that with the fingerprint sensor, most dun use lock screen apps nowadays but I love the features of AcDisplay and I decided to use one anyway.
One problem I encountered is that sometimes when you unlock AcDisplay, you get the 'Device Administrator Locked' screen. I check my Settings > Security > Device Administrator and ensure that only AcDisplay is the only app Active.
The funny thing is that it does not happen all the time. Sometimes I unlocked AcDisplay I get to my homepage. Sometimes I get the Device Administrator locked screen.
I search around but have not really manage to get a clue on why this is happening. Anyone else has any idea?
eyz
anyone experience pubg exiting itself, while the game is loading into the match?
Suhr23
Nope. Maybe you can try shift the files to computer then format the card using phone then transfer files back from computer to phone? If second time, better change new SD card actually....
symbiote28
Yup i do my backup frequently so transferring of files back is not an issue except time consuming. This SD card is the second one i bought just 2 months back. First issue happened was to another different SD card but the lifespan was already about 5 years.
Makes me wonder i can't be that unlucky with SD cards.
5408854088
Last update so far is still the GPU Turbo.
Waiting for the 8.1 for new camera UI with AI disable function also haven't come. Now they released P20 AI default off, if only Mate 10 can get that.
I like the picture quality but prefer without AI.
Oh that means the additional AI-detected scenes, and option to disable AI is not out yet?
https://www.techradar.com/sg/news/huawei-mate-10-will-get-p20s-ai-camera-smarts
charleslin
Not for M10 series.
For P20 series the newer camera UI in 8.1 allows you to disable the AI but it’s on by default.
Apparently the latest firmware turns the AI off by default for P20.
We need to have the new camera UI for the ability to disable.
But there’s actually a way to disable now, by using the pro mode, it will be natural no AI, as far as I can tell.
5408854088
Not for M10 series.
Seems that it is taking a long time for the update to come.
egnaro911
Got this recently, was using sandisk card. Then Try to play game or whatsoever also cannot... open image also cannot... so LL go change a new SD card and it work well now...
Suhr23
Oh you mean you can install game onto SD card? If I remember right, I thought Huawei does not allow for apps to be installed on SD Card,only data. But my old Samsung did allow apps to be installed on SD card.
egnaro911
I use my SD as default, becuz of that some game cannot run. So I think it should affect the game... Photo only can see thumbnail, cannot open.
ukyo100
After update notice that is using dual sim enable dual sim 4G the second sim always disconnect and connect again.. Now I've turn it off will monitor it happen again or not...
