Huawei Mate 10
Skyy
Done my mate 10 upgrade 2 days ago.
Did factory reset a few times.
Before I re-install all my app, not by restore method.
So far everything works smoothly.
All major firmware upgrade need to factory reset (clear all cache) and re-install app.
Ya install from scratch is definitely the best.. just that it's a huge waste of time. Think I'll use the google back up and restore method, at least that one downloads everything from play store and if I'm lucky, the app data gets restored too.
Why u need to do factory reset a few times? did u do once first, then upgrade FW, then do factory reset again before installing the app?
newcell
Sometimes one reset could not clear away bad residual memory, if any.
From past experience, good to do a couple of factory reset.
Yes, definitely time consuming but worth the trouble. All the hips about full restore from backup didn't works well from my past attempts. Fresh app and restore app data, works perfectly.
donetus
is any one using Google Messages on the Pro and non-Pro? If yes, are you able to use the Chat feature option (similar to what Google Allo does)?
linusz
can mate 10 connect to hisuite via bluetooth?
trying to retrieve sms via this way.
teoph04
Hi guys, may I know why I'm not getting the latest EMUI?
Sent from HUAWEI ALP-L29 using GAGT
HuatKway
Think have some problems. Try changing to another Telco sim card. I tried yesterday from starfug to m1 and it triggered the update
teoph04
Tried switching sim card and via Hicare, still no updates... Sian
CS0287
After you switch sim card (another Telco) then try restart your phone and launch hicare again?
Or clear hicare cache and retry ..
teoph04
Tried all suggestions... Still no update. Nvm lah, thanks guys haha.
newcell
Not sure any help but sharing as below.
Before my mate 10 upgrade. Not the pro. Hicare also didn't prompt me for the upgrade. That was few weeks after I learn from here about upgrade.
After backup all my important data.
I did factory reset (previous version) .
Than only I discovered hicare prompted about the upgrade. It was not immediate after I FReset. Think was on second day.
I suspect there is issue with mate 10 Notification.
After upgrades several days already.
Am still not very satisfied with it notification features related to WhatsApp, Telegram and Facebook.
Compare with my other phone, Asus zenfone, every app notifications came in perfectly. My WiFi doorbell works too but not with mate 10. Tested with Samsung and works great too.
amazingone
I did factory reset to my set.
EMUI is aggressive in killing apps to achieve better battery life.
My telegram sometimes get killed too, even though I locked it in the recent apps menu and whitelist it.
newcell
Ooh, thanks for the hint.
Ya, very annoyed not getting notification from my WiFi doorbell.
Think I rather downgrade to other phone. 😔 Staying away from mate20.
mikeymesina
Think I rather downgrade to other phone. � Staying away from mate20.
Try to manually manage all those apps you want to receive notifications from. Make sure you allow them to run in the background and to auto launch. I never had any issues with my notifications and battery is still fantastic.
Sent from Huawei Mate 10 using GAGT
linusz
How'd battery life for everyone
Mine shows 2h 53m at 25%
Posted from PCWX using ALP-L29
newcell
OK, many thanks, will try. 😄
linusz
have a huawei original powerbank (brand new) to sell. anyone interested please let me know.
linusz
also to check - anyone' battery need to be replaced after 1 year of use?
fully charged - indicates at most 2 days.
