Huawei Mate 10
j4nfz1981
Used to have issues untill I allow the apps to run at bkgd, auto launch, etc.
Try to manually manage all those apps you want to receive notifications from. Make sure you allow them to run in the background and to auto launch. I never had any issues with my notifications and battery is still fantastic.
Sent from Huawei Mate 10 using GAGT
j4nfz1981
I tried locking in recent app. It doesnt work as well. Try doing the setting within special permission. The auto launch, etc. It worked for me.
EMUI is aggressive in killing apps to achieve better battery life.
My telegram sometimes get killed too, even though I locked it in the recent apps menu and whitelist it.
linusz
Tried to use password vault but it doesn't capture mobile app password
Anyone tried? Or I doing it wrong
Posted from PCWX using ALP-L29
Soulfly
I've just updated my Mate 10 to Android P through HiCare. But after the update, I couldn't find the Bokeh effect icon in portrait mode. Anyone knows where the icon went to or was it removed? Thanks guys...
knave
Think you must select the a pattern.
Camera, choose portrait mode. Left side will appear a button. Click on it. Need to select a bokeh effect I think. If you choose none, then it will not work
Posted from PCWX using HMA-L29
mun
Just received a minor update today.
Posted from PCWX using BLA-L29
mun
After upgrade, anyone know where is qr scanner for mate 10?
Swipe down from the main screen and click on the top right icon. Then, scroll to the left for qr scan mode.
amazingone
Also received a system patch update too
Posted from PCWX using HUAWEI ALPS
Soulfly
Thanks for the reply. Instead of the bokeh icon. Now there's 2 other icons and a beautify icon. I can't seem to locate the bokeh icon...
newcell
Thanks, found with your help. 👌
I need to tap on search bar than the top right icon appears. Not sure is it able to re-config it for quick access.
KYLee
Noticed ever since the emui 9 update, phone itself seems to be buggy, sometimes apps will crash or for example, in whatsapp, while typing halfway the app will close by itself and it goes to the homescreen. anyone else experience this?
Zappalapa
after reading the posts here i think i better not update.
dont wanna go through the pain of missing/delayed notifications and lag
