Huawei Mate 10
ice888
Does the Mate 10 work with dual VOLTE? I just popped in the TPG sim CARD slot 2 but can't seem to find the option to enable VOLTE.
amazingone
Mate 10 support Dual VoLTE, but TPG's VoLTE service currenty support Nova 3i only, with support for Galaxy S9 series, P20 series and Mate 20 series coming up next.
T3rmite
hold back the update first.
I notice battery drain is faster than before update. (10% drop after reading web novel and FB for like 30min. 100% -> 90%)
Could be a calibration thing, but will monitor for now.
Otherwise, its working fine.
Will trial it for a few days before updating here again.
T3rmite
Quick update, the battery drain issue seems to be gone. It is back to normal again after one day of usage.
One hour of reading novel on chrome 7% drop. (81%->74%)
donetus
i'm planning to upgrade the non-Pro's micro SD card. would it be better if I get the 128GB Sandisk A1 or 128GB Strontium Nitro A1?
ice888
Is there a feature to auto switch the data? I realized it have to repeatedly switch the primary data sim whenever TPG has no coverage...
xtemujin
I've just updated the firmware.
Location Mode options is gone to switch from Use GPS only, Wifi and Mobile Networks.
The home button also now combined with Google assistant.
cybertech
Me on starhub also showing 159 update just checked.
Btw, what will be the correct way to perform a backup and full restore back to current firmware if some of my important apps do not work after update to new 159? Thks.
Zappalapa
where is the option for "keep wifi/data on when phone sleeps" ah?
edit: found it on battery > more settings
CS0287
Anyone has this error when trying to take photo from 3rd party app?
This happened to me for a few apps.
xtemujin
Location Mode option is missing, the handphone now fast battery drain due to GPS not able to be turned off.
piyozz
I was about to ask about this too. Just updated to v159 on non pro. Noticed my battery draining very fast. Wanted to find the location to see if it was set wrongly. Can't find the locating method icon too!
piyozz
Anyone can advise on this? I also face the same issue, the phone doesn't auto switch data. I tried switching "dual sim 4g" on also not helping.
j4nfz1981
Cannot also. Need to manually enable the other sim to get data from other sim. Btw, when u enable dual sim 4G, does both ur sim displayed 4G at status bar? Mine only TPG 4G even though both also set to auto, G/WCDMA/LTE.
