Huawei Mate 10
CS0287
So far i tested nova and evie launcher. You can also google best launcher and there will be a list. Can try which suits u.
Ok, now that i have tested both launcher, safe to say that huawei kinda being a jerk for the following roadblock they implement for 3rd party launcher. And emui kinda sucks
1) lock screen app is not usable in 3rd party launcher. You either have to press the side button to lock or customize it at the 3rd party launcher
2) customise lock screen (double tap/swipe) to lock screen require either fully lock once activate (must use pin/puzzle swipe) or 5-10sec delay b4 lock. Both option fingerprint will not work as intended
3) icons at stock emui is buggy. Some might change. Some might not. No way to customise it individually. Using 3rd party launcher will face the lockscreen issues
4) AOD is the worst. No support for 3rd party app like whatsapp/telegram/messenger etc notification. EVEN IN EMUI 9! DARRNIT
Totally agree
CrispyPeddler
i really like nova launcher since it really integrate into the system (not like everytime need to click to activate it)....but the lockscreen issues really turn me off..any workaround for those seasoned 3rd party launcher user?
CS0287
Change phone I guess? Haha
knave
Free one can try Microsoft Launcher also. Can set gestures for double tap to lock
Posted from PCWX using HMA-L29
CrispyPeddler
will it have the same issues once you double tap to lock and to unlock you need
1) pin/swipe to unlock
or
2) 5-10sec delay to lock?
CrispyPeddler
anyway, i found a proper way to lock screen in nova.
go widget and put in nova action...then choose screen lock for the button...allow it to operate through the system...and wala, u get the lockscreen app that u just press to lock the screen and unlock with fingerprint (no popup on pin/swipe and no delay)
CrispyPeddler
f***...i restart my phone and it requires me to put in pin instead of usual swipe....i tried all my pin combination and still wrong! is there anyway to go for swipe instead of pin!?
eyz
it usually require pin to log in upon restart or 3 days.
your problem looks serious.
CrispyPeddler
yea usually it only prompt me using swipe after 3 restart. i just change my launcher to nova...and restart my phone..it only prompt me pin...tried all my comination and none of it works...next try the phone gonna lock for 30 minutes..f*** totally screwed...
roz_sid
hi, i tried nova. but somehow my notifcation dots on icon app is gone. wen i receive new message the dots nvr show. how to make it appear?
CrispyPeddler
you need to buy nova launcher prime. its only available for prime user iirc. its called app badges or something
amazingone
EMUI isn't friendly with 3rd party launcher, that's why I stick to EMUI and try to love it. :o
Posted from PCWX using HUAWEI ALPS
OutBreak
Indeed.. the gesture doesn't play well with Nova Launcher. EMUI looks quite dated compared to Nova. :(
