Huawei Mate 10
CS0287
Oh.. I am using Nova Launcher Prime.. Let me try the stock Huawei launcher.
Thanks for the tip!
:o
I tried stock launcher for 5mins .. went back to Nova.
The icons are HUGE on mate 10 pro, is there any way to make it smaller? The huge icons and widgets are so ugly.
eyz
maybe try other theme.
or change the home layout
hermes76
I'm on M10P n juz realised my OTG not working after PIE update, anyone got same issue?
Sent from HUAWEI Mate 10 Pro using GAGT
HuatKway
Any one has got issue with other party not able to hear u during calls? Weird. Happened when I upgrade to latest build. Many times call other party can't hear me. But I did a mic test ok
OutBreak
I am using Mate 10 non pro. The icons looks normal to me. I don't think you can change the icon size.
Probably you are used to the icon size in Nova Launcher. :D
newcell
In Setting/Display/Text and Display size
Not sure any help to chge icon size.
CrispyPeddler
btw bros and gurus here, any luck in changing the icon for mate 10/pro phone? without using 3rd party launcher.
tried huawei themes app and download some icons from google store, change most of the icons but some still remain as default..
any method to change it individually for each app?:s12:
CrispyPeddler
Now using the amoled always on. But battery jiak welly fast :(
u can try nova launcher paid version. they have this double tap function.
moi still thinking whether to pay for premium nova launcher or not...stock emui cant change to 3rd party icons...:s22:
CS0287
:s22:
Nova is good, just that EMUI gesture does not work well with it. Buggy...
Is there promotion for Nova prime now? I remember from time to time they will have promotion of 99 cents... I bought Nova at 99cents previously.
roz_sid
alight will try outttt thx :)
HuatKway
Think the Nova double tap is to off the screen rather then double tap to wake like LG. Been using nova previously
CrispyPeddler
seriously? damn. miss the chance. now its usd7. hmmm been trying out nova non prime...quite smooth with gesture and stuff leh. most probably i havent use it for long
CrispyPeddler
yea. the annoying thing is that the lock screen icon cant be used in nova launcher. so, need to press side button...or get prime for double tap to lock screen:s22:
roz_sid
so which is the best free launcher now? can resize icons ones
CrispyPeddler
So far i tested nova and evie launcher. You can also google best launcher and there will be a list. Can try which suits u.
Ok, now that i have tested both launcher, safe to say that huawei kinda being a jerk for the following roadblock they implement for 3rd party launcher. And emui kinda sucks
1) lock screen app is not usable in 3rd party launcher. You either have to press the side button to lock or customize it at the 3rd party launcher
2) customise lock screen (double tap/swipe) to lock screen require either fully lock once activate (must use pin/puzzle swipe) or 5-10sec delay b4 lock. Both option fingerprint will not work as intended
3) icons at stock emui is buggy. Some might change. Some might not. No way to customise it individually. Using 3rd party launcher will face the lockscreen issues
4) AOD is the worst. No support for 3rd party app like whatsapp/telegram/messenger etc notification. EVEN IN EMUI 9! DARRNIT
