Huawei Mate 10
knave
Why unable? I can connect to such WiFi with no issues at all. If your browser for some reason can't be auto launched, then you manually launch it yourself. Browse to some website like hwz or something and the WiFi which you are trying to connect will redirect you to their login page.
Have you updated to Pie?
If yes, check if you have enabled private DNS feature. If yes, disable it to connect to those free wifi
Posted from PCWX using HMA-L29
DOINK1
Just updated to PIE recently. I will try to disable it. Hopefully it will be able to open their bowser. Will update here Again. Thanks guys. :)
Those public WIFI still able to connect but those WIFI that leads to their page bowser is unable open.
piyozz
Could anyone help me pls, after the update my phone keeps killing my data once my phone screen is off. Like few second after the screen off my radio will be cut off. I have checked and make sure I tick the keep wifi and data connected when phone sleep. And also reset my network connection... Nothing helps. Has anyone else have such issue? How was it resolved?
Shib
Go to Battery - > App launch and manage your radio app manually. There is one setting that says do not kill app in background.
Sent from HUAWEI MATE 10 using GAGT
knave
Confirm is due to this. I recently traveled and couldn't connect too. You try with singtel wifi at Mac / mrt. Same problem. Cos their login page is a custom page hosted on the router.
Thus requires the router's DNS to be used so that your phone can find the page using the name.
piyozz
Thanks, I tried that. It doesn't solve the issue. I reset all setting then issue resolved. Now restoring all my settings.
DOINK1
Have tried to disable the DNS feature but still unable to connect to the hidden WIFI..:s11:
OutBreak
Anyone find that the gesture navigation is buggy also? EMUi 9 really feels like beta software..
piyozz
I feel that after the update, like the button not responsive as before and a slight lag. My battery life also suffer due to the patchy network. After I did the 'reset all setting' every works fine now. It's abit troublesome to have to redo all my setting again.
Zappalapa
while everyone here seems to be commenting that the battery life got worse...i felt like my battery can last longer now given same usage habit :o
i realised that the kill all apps is buggy. apps are still running in the background
CrispyPeddler
Gestures works smooth on my Mate 10, no issues.
Posted from PCWX using HUAWEI ALPS
Same here. works smooth with no issue. loving it so far.
imo its better than fluidNG.. i tried fluidNG and there's so many bugs and error. even hiding the bottom bar will pop up and whole thing stuck..need to re-enable using the app agn.
i think after the update can see the battery drain fast. but after few day usage it somehow get optimized and get better. so far can see most ppl commenting bad at first, getting better after few days used
haylui
Anyone uses mate 10 with SD Card can view all albums in the Gallery app?
