Huawei Mate 10
iamnagel
Are we able to use phone to pay for buses and mrt now?
Posted from PCWX using ALP-L29
rp2019
anyone else
port easy spoil. known isssue. sending in to huawei service center in orchard
amazingone
how does this work? is there a specia requirement on the card linked to Google Pay where it has to be NETS-enabled or Flashpay enabled or something?
It has to be a Mastercard debit/credit card.
Posted from PCWX using HUAWEI ALPS
Paul Lee
piyozz
Does anyone here use google photo? If you are, does your phone sync with the app? I have been trying to sync the app to upload my photos but it's not working. Tried clear cache also don't work...
cybertech
Possible to set daily limit for data? Just wondering.
Sent from HUAWEI BLA-L29 using GAGT
Yes is possible
donetus
donetus
I've using it to sync the photos on my phone. have you enabled the back and sync option under the Photos' Settings?
piyozz
You mean the one under settings right? I have enabled that. When I load into the app, it will show me the number of photos to sync with a circle behind. But I waited with my wifi on, the number doesn't decrease at all... IDK why?
TheOutsider
Thanks!
It seems that for the Google Pay, I can't add any of the travel pass. It only allows me to add Las Vegas Monorail and myki. NO support for SG.
For the Translink, I've already had the card activated.
Ezlink/Flashpay support only coming later this year if not wrong. I tried too to no avail. If google can find some info on this haha
CS0287
If you are using MasterCard, it will works . Just tap as per normal wireless payment in shop.
I just tried this morning, able to deduct directly.
but I did register for simplygo before I tried, not sure if it matters.
donetus
quick one.
we just need to open Google Pay and set that card (that we registered in Translink) as the default card so that it'll work?
Hahha. I don't want to hold the queue when I go coz you know how some would like to stand very close behind you when you enter the gantry and they'd get annoyed when there's an error when you scan the card. :s13:
