Huawei P40 Series
sos911
Many thanks again for all your help and contributions, at the very least, the biggest concern of mine has been addressed.
I'll get the p40 pro+... Just still considering between gms or hms lol
Sent from somewhere out there using GAGT
P40 Pro + I think no e-sim support based on circle's-life list of supported devices for their e-sim sub. Take note if you want to use e-sim in the future.
Sent from HUAWEI ELS-NX9 using GAGT
Yuripa
Nope, haven't considered esim yet.
Too futuristic for me for now.
Thx for the heads up though :)
Ghost^recon
hi guys, my contract is up in november and i can get a new phone literally for free.. currently using mate 20 pro and loving it.. thinking of getting the p40 pro but how is it without google functions?
sos911
Get P40 Pro if your subscription plan allows you to get it for free.
If you can live without some key apps eg SingPass, tracetogether, OCBC etc not being able to run on P40 series at the moment then go ahead and get it.
Go for P40 if you are into photography.
Go for Mate series if you prefer Jack of all trade type.
For me , without GMS running is perfectly fine. Most of the time I sideload APK to the phone but again you need to be sure the APK you install is from a reliable source eg. APKPURE.
yhw22
Just curious, do u guy tried golden snap? Does it really working?
Sent from HUAWEI VOG-L29 using GAGT
sars8888
This is another deal breaker for some as HW has decided to disable call recording in EMUI 10.
There should be alternative app eg. ACR
No. It is not working anymore. ACR now can only record my voice but not the other party.
RobbieFowler
Anyone got MS authenticator working?
Did a side load, looks like it is working except for the error msg that says Google service is missing which I doubt so. Just need confirmation before I port my accounts over.
Need to use it for my work.
So far no issue with most of the app. Even for Gmail, drive or etc, I just use the web version. No much diff. Google authenticator is a pain though but I have pretty much switched to 2fa with sms.
davidwong
Isn’t p40 pro plus better? I do agree just main camera, p40 / p40 pro plus are the best till date.
But unless you have a main phone, one will consider other things like apps supported, screen, battery life are taken into place .
i researched extensively on phone cameras, so far P40 series still tip top
ecneret_eel
yes i was referring to Pro and Pro Plus
but Pro Plus is still commanding a significant premium
one of my colleagues is using P40 Pro, he sits beside me
with a little bit of effort he has full access to everything including Blackberry Work so i feel it’s quite ok
ecneret_eel
i heard from a telco staff; if you side-load GMS, it voids they warranty
anybody here using the phone for what it should be? aka HMS?
