Huawei P40 Series
bedlamite
There isn’t a camera in the world that can, or will ever make up for the loss of GMS, but that’s just me. I use Google Pay for everything and losing that is an instant dealbreaker.
tohchr
thanks for the info!
btw how did you guys port your whatsapp history into your P40?
any advice? coming from iphone
My whatsapp are all work related and so I dun care about migrating. My personal friends and family are all using telegram. No headache when I change phone.
ecneret_eel
i actually need my whatsapp history because of work..
wondering if Dr Fone would work with Huawei... it’s still Android at the end of the day..
Yuripa
i heard from a telco staff; if you side-load GMS, it voids they warranty
anybody here using the phone for what it should be? aka HMS?
No it doesn't void any warranty.
Warranty is covered by huawei.
While they would recommend you not to sideload but Huawei Singapore already assured their customers that warranty is still covered because its a hardware warranty.
I assume that they have means to revive the phone in case of bricking but so far I haven't heard of any such cases.
Sent from somewhere out there using GAGT
Yuripa
Sideload if you wanna use gpay.
Yuripa
So far there are 2 proven methods to backup and restore WhatsApp msgs but its only from android to android -
Huawei cloud to huawei cloud.
Or backup onto huawei memory card and restore from there.
I haven't heard of iPhone to P40 series yet.
Maybe you can port from iPhone to android phone using dr fone
The do the above mentioned 2 methods or just directly sideload gsm into a p40 series and use dr fone from ur iPhone to a GMS p40 series.
Yuripa
I helped you to check on huawei app gallery but its not available yet -
Guess you need do try the other methods that I've suggested if you really want to use a p40 series phone.
sajokj
Buy P40 Pro Plus or Wait for Mate 40 Pro
I m currently using Mate 20 Pro (Bought it on launch day)
Is it better to wait for Mate 40 Pro or select Mi 10 Ultra or P40 Pro Plus.
Any suggestions?
Yuripa
Any suggestions?
Wait for mate 40 series to be released in Singapore if you're not in a rush, P40 pro + price will drop once mate series is out.
If you're on a budget plus don't need local warranty and if you don't mind to manually install Google apps you can consider getting mi10 ultra.
tohchr
Any suggestions?
I think Huawei having announcement on the 18th? If u can wait, just wait awhile more and I am sure the newly announced phones will caused the current models to drop in prices.
ecneret_eel
eh! seriously thanks for helping me out with this!
appreciate the effort... but wah.. that means i need another android to bridge the gap.. hmm
ecneret_eel
was looking at the youtube video again..
i guess even though we can get it to work eventually, getting GMS on the phone requires so much work
best to just accept HMS as it is, and use it accordingly
tohchr
If relied on something until cannot do apart, then next time difficult to try other brands. I'm using China 20x without google for almost 2 years, no issue. Only thing that I cannot do apart is native call recordings in mobile phones. Cos my coy a lot of prata king, call recording saved me numerous times. So, I would get China version Huawei or Asus rog 3 which had call recordings natively in build.
ecneret_eel
actually the one thing i need, is my whatsapp history
i can’t figure out how to port my iphone whatsapp history to huawei HMS that’s why i’m stuck
