Huawei P40 Series
vblues
I'm really tempted to get P40 Pro to replace my Mate 10 Pro which is still working like a champ. I suppose I can try to migrate away from Google which will take a long time and is a real pain but still doable, I think. Only thing is Google Pay which I use whenever there's a Paywave option. Probably have to start carrying around my credit card for this purpose. Inconvenient but still the P40 Pro might just be worth all these trouble. :(
OutBreak
Though you won't be able to update the app subsequently through AppGallery, unless you also install a 3rd party APK store to update the app.
Posted from PCWX using HUAWEI ALPS
Just do it manually or wait for FB apps to be available in AppGallery.
xenocide
Even Malaysian lady also know how to work around Huawei phone without GMS on the below links yet all of us here still debate life can't go on without GMS. :s13:
See the tips & trick on Huawei Apps gallery & sideload other apps on the video link:
https://www.youtube.com/watch?v=s_1MJBKsUzA
Hope the above links is helpful for those newbie who want to get huawei phone. ;)
chio bu spotted haha
but in deed there are some solutions to work around lack of GMS
you wouldn't know the real impact until u change to HMS
XiaoFu99
Anybody tried Android auto on huawei set without GMS?
OutBreak
Good for you then, this phone is ideal for your use case. I wouldn't make the assumption that Google Pay is unpopular just because you don't use it though.
Using Google apps/services on an Android phone? pfft who does that?
I am low SES. I only use Grabpay and DBS PayLah. Non US apps, so Dotard cannot ban it. :D
busfreaks
Waiting for the P40 Porsche design to launch then can replace my current PD
P40p use AI to remove passerby
Original photo :
Click the edit --> Remove passerby button
After processsing :
commie censorship jin tokong :s13:
Skyy
Only works for person behind the focused object. Magic has its limitations i guess.
"Like all technologies and the features they bring, AI Remove Passerby has its kinks. We confirmed with Huawei that the feature only works on passersby and photobombers that are behind the subject, and not in front. To ensure that AI Remove Passerby works as intended, the shooter also must focus on the face of the subject, allowing the yellow focusing box to appear right before you snap your photo. Considering that the alternative could likely be the conventional tripod-assisted photo-taking via multiple attempts, we'd choose to have AI Remove Passerby for the convenience it offers."
guess it makes sense to have the subject in front, then the TOF can work its magic on the subject..and it does need human intervention to tell it which is the subject. not sure if it will work in group photos or not, since there are multiple subjects ...
Skyy
dont think it works.. never tried it though.. this is a big bummer for me, i use android auto quite often..
lorettatay
I'm very interested in the remove passerby mode lol
Sent from Samsung SM-F900F using GAGT
19dino
Not sure if it's the right place to post, otherwise mod please remove my post.
Just pre - order P40 Pro, if anyone wishes to swap Freebuds 3 with Huawei Gt2 please PM me. Thanks.
maumu
Current P30 Pro users, are you going to upgrade to P40 Pro or P40 Pro+ (in June)?
P40 Pro has same 5x optical zoom as P30 Pro.. bigger sensor, more gimmicks (like the remove passerby feature) but I don't think it justifies the exchange with having no more GMS. May as well stay with P30 Pro.
P40 Pro+ on the other hand has 10x optical zoom but no more GMS. Of course probably in the range of $1.6k..
What's your take?
