ledcoolingfan
- Mar 30, 2012
My old Sitoca got bloat. But thats after more than 10 years usage.
thing i better get solid wood one
I'm using a Galant table too, for about three years already. I don't think you need to worry much about the table "bending" because the steel frame underneath it will prevent that from happening.
However, the finishing for the wood they used for the table-top is not the best. I once has something sticky stuck to the table, so I used some scotch tape to try and lift it off. The table coating (which is a thin piece of film) tore off. Can see/feel the wood underneath. The wood itself is not damaged or anything, just the finishing. Anyway, this also depends on which table-top you go for.
My father stands on my table to change the curtains. He is about 65kg. So, no worries. I recommend the "A" legs. I think they can withstand more than the "T" legs.
the wood for ikea like not solid if you knock on it, why not just buy those "office" table. those boring gray but use super thick wood
picture courtesy from renotalk.com
get ikea kitchen countertop.. and diy your own stand..
Centre no support? Can the stand be bought at ikea too?
Galant is particle board, a.k.a recycled compressed wood chips/saw dust glued together with some resin to form a plank. If you live long enough to damage a galant and get to see below the melamine foil finish you will understand what i'm sayingGalant wood is solid. Even if buy second hand, got no worries.
Cos T-leg is one leg do the work of 2, A leg is 2 legs do the work of 2, thus it has to be stronger than one A leg, probably why the price is such. Also galant's T leg looks a lot better than the A legs, at least to mehow come the ikea website put T-leg to be more expensive than A-leg? means T-leg is able to handle heavy weight better than A-leg?
wonder ikea still carry this a not? i want to make one 200cm table
That's why Ikea SG have a website: Home - IKEA
galant wood is chip wood, not taht strong and can bloat when soak for too long
can anyone take more photo of these desk ~! moi ish want to change desk !!
basic is 160cm long .. can add 40cm to each side..
default color black i think
default leg is leg on each corner.
$239(if i not wrong)
any SINGLE changes to color, leg , add on length all add $.
1)can choose glass(black glass or transparent glass?) or wood(my one or black)..
2)the leg can choose 1 T leg on each end of table or leg on each corner...
3) can add 40 cm to each side (i added 40cm to my table see pic)
addup i pay $350++ for table alone
pls drive and bring home yourself. delivery is xpensive. i paid $100++
and u can only choose from 3 days from date of purchase.
a)want other day delivery +$
b)want weekend delivery +more $ compare to a
c)live in private estate (3 floor and taller) without lift service +$.
d)each additional item beyond first item +$.
e) item above certain weight range +$.
f) installation service +$20.
a-e , each selection add $10-$30.
as for base delivery charge i forgot how much it is.
