iPhone 11/11 Pro
*adiBOY
Swee. Anyway was wondering la hor. Back then when i use my
Ipx(space gray) during a weeks later the side “skin” were peeled off... not sure if the MG will get peel off also anot.. lol
It’s more robust on the Xs so don’t worry about it.
*adiBOY
Looks like most buyer choose iPhone 11 green and purple 256GB, now delivered on 5 Oct.
Same goes to pro and pro max midnight green.
iPhone 11 will still be the most popular model so it’s not surprising.
kuanknightz
X user here. Not going to upgrade. Did consider the iPhone 11, but dropped the idea.
I was considering for the past few days, didn't upgrade from X to XS max because only thing changed is just screen size. Now add a new camera system... i am still undecided..
Jirachi
What’s the reason behind it?
Not much reason to, since my X is still working fine. I am those who also rarely use my phone. Data usage per month is around 1GB+ only. But as tradition, just sticking around during this period.
Jirachi
I know how you feel. Same thoughts went through my head after the announcement. Should I Pro Max? Or just Pro? But I want something bigger? Wasted... Didn't go XS Max last year. I am also looking for eSIM support preparing for Singtel support. Went to Comcentre shop yesterday to check, one guy told me eSIM will likely come with 5G which is next year. I forget about it already.
metamofia89
Reliable sources mentioned that the reverse wireless charging feature was disabled at the software end in the hours leading up to the event.
Perhaps that’s why we were quoted those silly amount of battery life gains? Those 4-5 hours gains by right should be for the reverse charging?
kuanknightz
Think biggest benefit as an X user to upgrade to Pro Max is:
1. Bigger screen
2. Better camera system
3. Better battery life
*adiBOY
Like I mentioned, the hardware is there but Apple disabled it in software.
The Apple Watch wireless charging has really killed the AirPower and reverse wireless charging for Apple.
